Wiring 2 horn buttons on Sparco Wheel
On a Sparco or Momo steering wheel, how do you wire the two buttons on the wheel without having the wires get tangled when you turn???
Take this steering wheel as an example: http://www.sparcousa.com/pswheel_street.asp?id=154
[Modified by ck279, 10:35 PM 2/6/2002]
On your EG i suppose? I have tried to wire the horn button for the EG/EK's with the center horn button but have failed to succeed. There was this ghetto trick i tried with a paperclip that worked for a while but then failed. What I have done instead was re-wire the horn to a separate location near the steering wheel with a simple toggle switch or push switch from radio shack and it works fine. But I know how annoying it is to find the button when you need it most. Just a food for thought. Maybe someone on this board has made their center horn button work out of the air bag harness.
boostin4door
Dec 14, 2008 10:09 PM
turbotime
Apr 22, 2005 04:35 PM
boostin4door
Nov 30, 2003 02:57 PM
