HELP MY BLINKERS DONT WORK BUT HAZARDS DO!!!!!!
Old May 23, 2005 | 04:06 PM
ME=ADRIAN's Avatar
Default HELP MY BLINKERS DONT WORK BUT HAZARDS DO!!!!!!
okay well all the sudden my blinkers stopped working the other day .
so far i already changed the blinker fuse thing and the switch.
what now??? could it be some messed up wires or?
oh yeah and the hazards work and i dont know if it matters any but i got sidemarkers too.
this is on my 94 integra.
TIA
Old May 23, 2005 | 04:49 PM
ME=ADRIAN's Avatar
Default Re: HELP MY BLINKERS DONT WORK BUT HAZARDS DO!!!!!! (DRAPESTER)
anyone?
Old May 23, 2005 | 08:34 PM
ME=ADRIAN's Avatar
please?
Old May 23, 2005 | 09:02 PM
Speed94's Avatar
get a test light and check the signal at the plu where it plugs into the blinker
Old May 23, 2005 | 09:16 PM
INNo's Avatar
hey, big time lurker here. im also interested in this because i have the same problem. my front driverside signal dont work but the hazard do, i havent got into looking at it, im thinking maybe its the Hazard/turn signal flasher relay (located in the interior fuse box), or maybe a messed up wire.
anyone experienced this and know the solution?
Old May 23, 2005 | 09:47 PM
ME=ADRIAN's Avatar
Default Re: (Speed94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speed94 &raquo;</TD></TR><TR><TD CLASS="quote">get a test light and check the signal at the plu where it plugs into the blinker</TD></TR></TABLE>
i'll try this
Old May 23, 2005 | 11:55 PM
Rocks A DC2's Avatar
Default Re: (DRAPESTER)
The signal bulb is a double filament bulb, one filament for signal and the other to illuminate. Check if both filaments are still good, i had the same problem couple of days ago, i just changed the bulb and it works fine now.
Old May 25, 2005 | 05:51 PM
ME=ADRIAN's Avatar
Default Re: (Rocks A DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocks A DC2 &raquo;</TD></TR><TR><TD CLASS="quote">The signal bulb is a double filament bulb, one filament for signal and the other to illuminate. Check if both filaments are still good, i had the same problem couple of days ago, i just changed the bulb and it works fine now.</TD></TR></TABLE>
i just changed the bulbs and they still dont work!
aarrrgg this is a pain in the ***!!!!!!!!!!
Old May 25, 2005 | 05:52 PM
revautousa's Avatar
my car is backwards, Hazards dont, Blinkers do
Old May 25, 2005 | 06:13 PM
ME=ADRIAN's Avatar
Default Re: (DA JeLLie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA JeLLie &raquo;</TD></TR><TR><TD CLASS="quote">my car is backwards, Hazards dont, Blinkers do</TD></TR></TABLE>i'd
LUCKY!!!!
rather my hazards not work than my blinkers
Old May 26, 2005 | 08:57 AM
neoclown2's Avatar
same here...
Old May 26, 2005 | 09:30 AM
Sam92Teg's Avatar
Default Re: (neoclown2)
Could be your ICU, Integrated Control Unit, at least on the 2nd gen integras it controls some functions of the blinkers, but this is last case senario.
Old May 26, 2005 | 10:53 AM
HGZ's Avatar
HGZ
you know the fuse for the hazards is under the hood near the battery right?
Old May 26, 2005 | 01:21 PM
sickofitall1113's Avatar
Default Re: (hgz)
why dont you call the acura dealership and ask them. or bring it to a shop they would probably tell you what it is for free, or meineke or midas im sure they wouldn't charge you. weird problem though.
Old May 26, 2005 | 04:06 PM
calxtreme's Avatar
it's probably the flasher relay. Replace it and see what happens.
Old May 26, 2005 | 04:47 PM
ME=ADRIAN's Avatar
Default Re: (sickofitall1113)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sickofitall1113 &raquo;</TD></TR><TR><TD CLASS="quote">why dont you call the acura dealership and ask them. or bring it to a shop they would probably tell you what it is for free, or meineke or midas im sure they wouldn't charge you. weird problem though. </TD></TR></TABLE>
i'm probly gonna take it to the honda/acura dealer and see what they say.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by calxtreme &raquo;</TD></TR><TR><TD CLASS="quote">it's probably the flasher relay. Replace it and see what happens.</TD></TR></TABLE>
you mean the square fuse that makes a clicking sound when you use the blinkers or hazards?
if thats what your talking about i changed it already
Old May 26, 2005 | 04:56 PM
. a d a m's Avatar
One time, I turned my hazards on, and then my blinkers didn't work for a while. Then they worked. Good story
lol but seriously I'll try to remember what I did to fix it. You have to change some weird fuse, like to something totally unrelated. Just like on 1g tegs if the fuse for the horn doesn't work then neither do the brake lights (which isn't a fun thing to discover on the road if you don't know their out). Probably not the same as your problem, but I'll look into it.
Old May 26, 2005 | 05:25 PM
ME=ADRIAN's Avatar
Default Re: (Sh!ttyLS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sh!ttyLS &raquo;</TD></TR><TR><TD CLASS="quote">One time, I turned my hazards on, and then my blinkers didn't work for a while. Then they worked. Good story
lol but seriously I'll try to remember what I did to fix it. You have to change some weird fuse, like to something totally unrelated. Just like on 1g tegs if the fuse for the horn doesn't work then neither do the brake lights (which isn't a fun thing to discover on the road if you don't know their out). Probably not the same as your problem, but I'll look into it.</TD></TR></TABLE>
please look into it
i neeeed this
Old May 26, 2005 | 05:32 PM
HGZ's Avatar
HGZ
you checked your blinker fluid, rite?
you said you have side markers - did you install them yourself? you made sure to cover any bare wire with elec. tape, correct?
i've had some blinker problems before and didn't find out til later that it was because my dumbass didn't use tape. as a result, bare wires started touching the car.
Old May 26, 2005 | 05:56 PM
ME=ADRIAN's Avatar
Default Re: (hgz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hgz &raquo;</TD></TR><TR><TD CLASS="quote">you checked your blinker fluid, rite?
i've had some blinker problems before and didn't find out til later that it was because my dumbass didn't use tape. as a result, bare wires started touching the car.</TD></TR></TABLE>
yeah i installed them myself and no i didnt tape them up
i'll do that right now
Old May 26, 2005 | 05:59 PM
slipstreamxk1's Avatar
its prolly a bad ground, i have a similar issue, my rear passenger blinker dosent work. changed the bulb, didnt help. heh ran it through a car wash and it worked for a few days then hit a bumo abnd it stopped again lol.
elbeanerhatch
Nov 4, 2008 03:00 PM
EJ8TT
Apr 3, 2007 08:55 AM
EJ8chu
Nov 17, 2005 05:27 AM
classciv
Sep 4, 2004 10:28 AM
Bewkrazed
Apr 2, 2004 03:05 PM
