Aebs im on jdm b16.
I have searched around and could not get a clear answer on this. My question is will the aebs intake manifold bolt right up to my 94 jdm b16a or will I have to modify/cut/grind anything to make it work?
Thanks
Thanks
aye bro here is a thread on h-t about the aebs mani.
https://honda-tech.com/zerothread?id=1244473
scroll down to DelSolDon. he mentioned that he had to grind down the manifold to clear the alternator and the stabilizer. hope this helps you out bro. good luck
You only have to grind on first gen B16s, the rest (Iv'e been told) fit fine. I had to grind mind down because there was no clearance between the alternator bracket, and I've only seen other people w/ 1st gens with this problem. It is an easy 5 minute fix with a grinding wheel. Later gens have had no problems (that I've seen)
Thanks for the replies guys. I will let you know how it turns out. Are the ebay aems intake manifolds the real deal or are they some other brand? They are really cheap BIN for $115.00 thats cheap.
Thanks
Thanks
It's amazing that, for the same product, the price has gone up into the $170's range.
I found it at cnc-motorsports for $157 plus $15 shipping (satin version).
Why are they more expensive now than 8 years ago??!!
I wound up ordering from CNC-Motorsports.
And GOOD LORD the casting marks are awful. The insides of the runners look like they were cast by a 9-year old with Play-Dough.
Opened up the Throttle Body opening already (to match my 68mm tb). We're going to dig in, clean up the casting marks (smooth them out -- they look like a mine field), and port match to my head.
This intake is very poorly casted (even if it's a larger volume with bigger runners than stock). Sheesh.
alscrx
12
Oct 16, 2007 01:33 PM
alscrx
Oct 16, 2007 08:45 AM
Got Milk
Dec 16, 2004 07:52 AM
