suspension question
Guest
Posts: n/a
Most certainly the RC51 triple clamp will not be a direct bolt on afair to your rr, but you should be able to research a clamp that will fit both.... best just step up and get the Ohlins World super bike fork set.
rc51
43.0mm inverted HMAS cartridge fork with spring-preload, rebound and compression-damping adjustability; 5.1-inch travel
Dual full-floating 320.0mm discs with four-piston calipers
1000rr
43.0mm inverted HMAS cartridge fork with spring-preload, rebound and compression-damping adjustability; 4.7-inch travel
Dual full-floating 310.0mm discs with four-piston radial-mounted calipers
600rr (2004)
45.0mm HMAS cartridge fork with spring-preload, rebound- and compression-damping adjustability; 4.7-inch travel
Dual 310.0mm discs with four-piston calipers
600rr (2005)
41.0mm inverted HMAS cartridge fork with spring-preload, rebound and compression-damping adjustability; 4.7-inch travel
Dual radial-mounted four-piston calipers with 310.0mm discs
1000rr
600rr (2004)
600rr (2005)
1990sihatch
14
Jul 9, 2009 04:08 PM
