Rings for boost? Total Seal or JE?
Old Feb 6, 2002 | 01:03 PM
InfamousRS's Avatar
Default Rings for boost? Total Seal or JE?
Which would be best? Can you put Total Seal on the JE pistons, or should you use JE rings when using JE pistons?
Old Feb 6, 2002 | 01:04 PM
Type-ARR's Avatar
Default Re: Rings for boost? Total Seal or JE? (BLK94RS)
are you going to get a Turbo or just keep asking questions about them......?
Old Feb 6, 2002 | 01:19 PM
Phantom's Avatar
Default Re: Rings for boost? Total Seal or JE? (TurboR481)
not everyone wants to blindly hand their car and bags of money to a shop hoping to come out with an acceptable result
as for the rings, I don't have much experience, but I have heard to stay away from total seal rings
Old Feb 6, 2002 | 01:20 PM
Type-ARR's Avatar
Default Re: Rings for boost? Total Seal or JE? (Phantom)
ummm it was just a JOKE
InfamousRS's Avatar
Probaly just keep asking about them. j/k (hopefully)
Im going to buy the stuff to rebuild my motor when I get my tax return probably.
Well Theres 4 things I want to buy with my tax return:
Pistons/Rods
Hondata(not useful at all till I get a turbo)
Corbeau seats
ClutchNet stage 2 clutch and fly wheel
Right now I think I want to buy the pistons & rods.
I don't think I will beable to get a turbo till August though. Atleast my motor will be built to hadle it though.
Old Feb 6, 2002 | 01:32 PM
Tomakit's Avatar
That must be one nice tax return!
Tom
Old Feb 6, 2002 | 01:39 PM
InfamousRS's Avatar
Default Re: Rings for boost? Total Seal or JE? (Tomakit)
I just re-read my post. I made is it sound like Im going to have enough to get all of the stuff. I ment for it to sound like im getting enough to get one of those. Im getting just over $600, so I'll have to add a little to get the rod/pistons. I WIpoo poo WAS ENOUGH TO GET ALL OF THAT!!!!
Anyway, lets get back to the piston rings.
Old Feb 6, 2002 | 01:43 PM
Projekt20's Avatar
Don't JE pistons come with the rings? Anyway....use the JE, I heard that Total Seal don't do what they're named very well.
-Trung
Old Feb 6, 2002 | 01:48 PM
InfamousRS's Avatar
Default Re: Rings for boost? Total Seal or JE? (Projekt20)
Can someone confirm that JE's come with the rings? Are the JE rings anygood?
Old Feb 6, 2002 | 01:50 PM
Ben Huynh's Avatar
JE pistons don't come with rings. We include the rings with the JE pistons we sell.
Old Feb 6, 2002 | 01:56 PM
InfamousRS's Avatar
Default Re: Rings for boost? Total Seal or JE? (ben@importparts.com)
Ben: So the price you quoted me this morning includes the JE rings? What do you think of the JE rings?
Old Feb 6, 2002 | 03:35 PM
threatcon13's Avatar
New User
i got some 9:1 pistons through importparts. came w/ the rings.
Old Feb 6, 2002 | 10:36 PM
Ben Huynh's Avatar
JE rings are great and seal better than most.
Old Feb 6, 2002 | 10:43 PM
InfamousRS's Avatar
Thanks Ben!
Old Feb 7, 2002 | 05:26 AM
b18b98's Avatar
i can vouch for that...thanks again ben...the rings came in this morning
Old Feb 7, 2002 | 07:28 AM
Rob03Pro5's Avatar
Default Re: Rings for boost? Total Seal or JE? (b18b98)
First off, the reason some people think Total Seal rings are bad is because they try to use the "gapless" rings on a STREET motor. This is bad because in a daily driven motor, there NEEDS to be some blow-by. The rings do what they are intended to do, its just that people use them on the wrong application. I have Total Seal rings.. but they're the "classic ring set." Which means they're like ordinary rings (non-gapless) but made by Total Seal.
Old Feb 7, 2002 | 08:21 AM
Suprdave's Avatar
Default Re: Rings for boost? Total Seal or JE? (Rob92SC)
Could it be that the TS Rings weren't properly designed for the Honda Motors? Your using it in a Saturn, which is kool and all...but your not comparing apples to apples. I heard TS Rings rock in alot of V8 Applications, but they might not have redesigned them for the close tolerances of the B-Series motor. Their lack of R&D is probably where the problem lies.
Suprdave
Old Feb 7, 2002 | 08:57 AM
Rob03Pro5's Avatar
Default Re: Rings for boost? Total Seal or JE? (Suprdave)
Pistons are pistons.. rings are made to fit pistons. What is so different on the cylinder sleeves of a Honda compared to a Saturn or any other car? The material is the same. What is the difference between JE pistons on a Honda than any other JE piston for another car???
WTF?? Close tolerances on a B-series motor?? When you get aftermarket pistons, you go by the tolerances that the piston manufacturer recommends. Please reevaluate your info/argument.
Old Feb 7, 2002 | 08:59 AM
dustin's Avatar
Close tolerances? The rings are supposed to sit as close to the cylinder wall as possible in all motors..
Dustin
Old Feb 7, 2002 | 09:04 AM
Rob03Pro5's Avatar
Default Re: Rings for boost? Total Seal or JE? (dustin)
"close tolerances" is a relative term... you cannot run TIGHT tolerances on a forged piston that is going to expand when it gets hot.
Old Feb 7, 2002 | 09:08 AM
dustin's Avatar
Well, we're talking about rings
Old Feb 7, 2002 | 09:11 AM
Rob03Pro5's Avatar
so you're saying you can run different tolerances for rings and pistons?? dont think so. Maybe you're talking about ring gapping.. which is a common thing for people to mess up when installing rings.
Old Feb 10, 2002 | 01:15 PM
speedworks's Avatar
total seal rings suck. oil will drip from your exhaust pipe. when you call their tech line it will always be something that you have done and never their fault. use the je rings and you will have no problems
Old Feb 10, 2002 | 02:11 PM
dustin's Avatar
What? The rings are spring fit against the wall, and the pistons are deliberately smaller...
Old Feb 10, 2002 | 03:26 PM
DRAGLS's Avatar
I have total seal extreme gapless rings on a LS motor for 2 years now I run 16pounds and I know they are the best rings out there right now I also run small gaps .014" top .011" second .
