blue smoke every so often while driving valve seals?
Old May 23, 2005 | 10:46 AM
egvtec's Avatar
Default blue smoke every so often while driving valve seals?
OK I just got done installing a jdm b16 into my hatch. I have a turbo kit on it and there are no leaks in the feed or return. I just got it running the other day and while i was on a two hour drive i would see blue smoke come out in little clouds every so often. Also almost the whole time i am driving i smell a burning oil smell from the engine bay. But sometimes it goes away. like i said it only blows a small cloud of blue smoke every once in awhile. Any guesses? i thought it may be the valve seals but i am not sure, return is not kinked or anything. Any guesses?
Old May 23, 2005 | 11:54 AM
egvtec's Avatar
Default Re: blue smoke every so often while driving valve seals? (egvtec)
anyone?
Old May 23, 2005 | 02:32 PM
1SlowB16EF's Avatar
out of the exhaust? could be blow by or could me a pcv problem could be rings could be valve seals
Old May 24, 2005 | 08:45 AM
egvtec's Avatar
well today i was downgearing till i got to where i stopped, as soon as i stopped i looked and it was blowing smoke out of the exhaust????
Old May 24, 2005 | 09:01 AM
Takumi Fujiwara's Avatar
Default Re: (1SlowB16EF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SlowB16EF &raquo;</TD></TR><TR><TD CLASS="quote">out of the exhaust? could be blow by or could me a pcv problem could be rings could be valve seals </TD></TR></TABLE>
Old May 24, 2005 | 11:25 AM
egvtec's Avatar
Default Re: (Takumi Fujiwara)
pcv is fine and i checked and there is no blow by
Old May 24, 2005 | 05:34 PM
egvtec's Avatar
Any other guesses?
Old May 26, 2005 | 02:40 PM
egvtec's Avatar
Default Re: (egvtec)
OK here is exactly what it does, when i am going around turns or going straight and i am in high gear pulling lots of vacuum it will be fine, then when i go from high up in a gear to giving it gas it will blow some blue smoke and be fine untill i do it again. like i said its only when i am downgearing and then give it gas.
Old May 26, 2005 | 02:56 PM
LSVTEC 91 Civic's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egvtec &raquo;</TD></TR><TR><TD CLASS="quote">OK here is exactly what it does, when i am going around turns or going straight and i am in high gear pulling lots of vacuum it will be fine, then when i go from high up in a gear to giving it gas it will blow some blue smoke and be fine untill i do it again. like i said its only when i am downgearing and then give it gas.</TD></TR></TABLE>
Try this...
Hopefully you're running a good, thick oil.. like M1 0w-40
Old May 26, 2005 | 03:19 PM
egvtec's Avatar
Default Re: (LSVTEC 91 Civic)
I am running castrol 10w-30 part synthetic in her right now. also i did check the pcv valve and it was rattling around i was told that was a sign that it is ok.
I dont see the pcv system being a problem with this though.
Old Jun 3, 2005 | 06:38 AM
PogKai's Avatar
I have the same problem. Every 200 miles or so I have to add an oil quart and changed a fouled spark plug.
Old Jun 3, 2005 | 09:20 AM
EK_GSR's Avatar
Default Re: (PogKai)
sounds like a piston rong... i had a very similar problem... one of my piston rings aligned... which is completely uncommon but it sounds like it has to do with the rings... does it only happen when u are in boost or as soon as u left off from being in boost and it lets a bit of smoke come out..... and then it is normal again...
my problem would only show as soon as i left off, after being in boost.... and compression started to drop.... have you done a compression test ??
Old Jun 9, 2005 | 06:23 PM
prism's Avatar
I still wanna buy ur car, sorry to go off topic, 757 233 9542 please call.
Old Jun 9, 2005 | 09:49 PM
b18ccivics's Avatar
sounds like oil drain not to good or oil seals in the turbo not the best. Do you have a header for it ? Take off the turbo and run it na and see if it still smokes. If it does it sounds like pcv or rings but i bet it is the turbo or drain.
Bootz
Dec 30, 2018 04:38 PM
sde780
23
Feb 19, 2013 05:02 AM
KevinSmith88
Feb 23, 2009 04:20 PM
jdmcivicb16a2sc61
Oct 5, 2006 05:17 AM
viprcr1
Mar 5, 2004 02:32 PM
