Rear Disks in my CRX?
Old May 23, 2005 | 09:36 AM
KaoticSnow's Avatar
Default Rear Disks in my CRX?
after doing a bit of searching I hear I can use the assembly out of...
1990-91 Civic or CRX Si
1990-93 Integra
1994-01 Integra
if I also want to swap my 4lug hubs for 5lug hubs what else would I need if its possable.
Old May 23, 2005 | 09:48 AM
Mach69's Avatar
Default Re: Rear Disks in my CRX? (KaoticSnow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KaoticSnow &raquo;</TD></TR><TR><TD CLASS="quote">
1990-93 Integra
1994-01 Integra
The 4th gen Civic hatchback never came with discs. The crx si did from '90-'91. The '90-'01 Integra is good (any <U>will</U> work, include type R, which is 5 lug). Also, any civic from '92-'00 that had a rear disc will also fit your crx. I am not sure about RSXs or the newer civics.
Like I mentioned, just buy the rear brake/suspension assembly from a type R and put it into your crx. And presto, 5 lug.
Old May 23, 2005 | 10:04 PM
KaoticSnow's Avatar
kewl, I never said but its a '89 CRX
one more thing how about for the 5 lug up front Still just ITR Hubs?
Old May 24, 2005 | 04:54 AM
fujii13's Avatar
Default Re: (KaoticSnow)
am i the only who feels 5 lug isn't worth it? it's been done enough time it's not special or anything anymore, and there's absolutely no benefit in running a five lug over 4 lug (of course, i don't feel there's any reason to run anything bigger than 15-16" wheels, either).
for me, it's all about functionality.
Old May 24, 2005 | 06:21 AM
MtnCRX's Avatar
Default Re: (fujii13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fujii13 &raquo;</TD></TR><TR><TD CLASS="quote">am i the only who feels 5 lug isn't worth it? it's been done enough time it's not special or anything anymore, and there's absolutely no benefit in running a five lug over 4 lug (of course, i don't feel there's any reason to run anything bigger than 15-16" wheels, either).
for me, it's all about functionality.</TD></TR></TABLE>
i feel the same way. If it aint broke or hurting the car, dont fix it.
Old May 24, 2005 | 06:26 AM
SwissChEz82's Avatar
Default Re: (MtnCRX)
You can go to PasswordJDM and get the whole rear disc conversion for 200.
Old May 24, 2005 | 06:32 AM
Kryogen's Avatar
Yep, that being said, why swap to Disc? Theres no functional gain whatsoever from drums to disc. The only thing you gain is a little bit of looks, and quicker brake changes.
Unless you Roadrace your car all week then do AutoX on weekend you dont need disc brakes.
Old May 24, 2005 | 06:36 AM
mahatma's Avatar
Default Re: (Kryogen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kryogen &raquo;</TD></TR><TR><TD CLASS="quote">The only thing you gain is a little bit of looks, and quicker brake changes.</TD></TR></TABLE>
That's all the reason I needed
Old May 24, 2005 | 06:42 AM
MtnCRX's Avatar
Default Re: (mahatma)
get bigger fronts. thatd look just as nice while functioning a lot better.
Old May 24, 2005 | 07:00 AM
Kryogen's Avatar
Bigger or heavier discs in general are going to slow you down, given the extra ratational mass.
iloveb16
Suspension & Brakes
Mar 16, 2007 01:25 PM
crx90rcr
Nov 5, 2004 11:26 AM
sebmour jdm
May 26, 2004 03:41 PM
red civic standard
Oct 21, 2002 11:25 AM
