Roaring in Rear of 91 CRX SI
When driving I'm hearing a roaring sound in the driver's side rear of my si. Could this be a wheel bearing problem. Any suggestions would be appreciated.
Thanks.
Thanks.
it is most likely your wheel bearing...pretty easy to do, cost about $110 for all parts needed from honda...
wheel bearing
washer
nut
cap
wheel bearing
washer
nut
cap
sometimes its just tire noise...
but if it gets somewhat high pitched, then its a wheel bearing.
lift the corner, turn the wheel, feel for some roughness. that will tell you.
it's not a high pitch sound. It's definitely a roaring sound. From the insider of the car it sounds as if I have big Four Wheel Drive tires on the car but the noise is only coming from teh back. I have the same tires on all 4's and I don't hear it in the front or the passenger side rear. When I roll down the window I do hear tire noise coming from the rear driver's side though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator »</TD></TR><TR><TD CLASS="quote">it is most likely your wheel bearing...pretty easy to do, cost about $110 for all parts needed from honda...
wheel bearing
washer
nut
cap</TD></TR></TABLE>
wow $110, never ever spend $110 on some honda oem parts. Go on ebay, i think there are alot of different bearings that fit in the rear hub of 88-91s.. i even think 92-95 bears do. CHEAP! just look around!
wheel bearing
washer
nut
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shivern »</TD></TR><TR><TD CLASS="quote">
wow $110, never ever spend $110 on some honda oem parts. Go on ebay, i think there are alot of different bearings that fit in the rear hub of 88-91s.. i even think 92-95 bears do. CHEAP! just look around!</TD></TR></TABLE>
you get what you pay for...and oem is what i use...
wow i though i was the only one with the problem, mines a roaring sound too and if i turn or cruise right it stops but if im just going straight its ******* annoying. so annoying i think i may have gotten used to it
i had the same problem and it was so anoying that i cant even talk to people in my car while im driving and when i go faster it would get louder and quicker but if was the wheel bearings and now i can talk in my car now
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mycrx7 »</TD></TR><TR><TD CLASS="quote">wow i though i was the only one with the problem, mines a roaring sound too and if i turn or cruise right it stops but if im just going straight its ******* annoying. so annoying i think i may have gotten used to it
that is exactly what mine was, it was the wheel bearing...worth the change trust me...
</TD></TR></TABLE>that is exactly what mine was, it was the wheel bearing...worth the change trust me...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mycrx7 »</TD></TR><TR><TD CLASS="quote">bump cause i hate this sound </TD></TR></TABLE>
so do what i told you to do...
rob_typeR
Jul 27, 2012 10:29 AM
Paprika
Aug 25, 2006 08:24 AM
i paid $60 each from napa, then i pressed them into the hub using two sockets and a vice
