B20 long block into my 92 DA to beat ITR, is it worth it? Will it be a lot faster?
Old May 23, 2005 | 06:48 AM
2006CiViCsI's Avatar
Default B20 long block into my 92 DA to beat ITR, is it worth it? Will it be a lot faster?
Alright, I want to be able to beat a Type-R with I/H/E in a race, and Im considering getting a B20 block cuz its cheap. Then later going VTEC with it, but for now, will this be enough, with my factory LS tranny, or should I get a clutch and flywheel? Will that even be enough? Or is my best bet a GS-R swap? But my problem is that I dont have that much money to spend right now, and if I get the B20 Im dropping it in myself the way I get it from the junkyard, plus Im considering a ACT clutch and Fidanza 7lb flywheel. Does anyone have any clue wether that should be enough to give the type-R a good run, or any suggestions?
Thanks.
Old May 23, 2005 | 07:22 AM
Novtecdohc's Avatar
Default Re: B20 long block into my 92 DA to beat ITR, is it worth it? Will it be a lot faster? (2006CiViCsI)
It can be done with a B20 but im not sure if all you need is I/H/E... You need to look into some Cams and a good valvetrain.. Look into a ported head and maybe a intake manifold... then you should give it a run for its money...
Old May 23, 2005 | 07:30 AM
Uncle Ben's's Avatar
Cogent Argument Enthusiast
Default Re: B20 long block into my 92 DA to beat ITR, is it worth it? Will it be a lot faster? (Novtecdohc)
it will be enough... if you go b20 vtec. 140 hp vs. 197 hp is no match, youll need a hell of alot more than boltons to run with it. yes, low end torque is nice, but bottom line is, he will still spank you with boltons.
RedlinedEG
18
Aug 29, 2022 09:57 AM
beantowncoupe98
15
Apr 30, 2011 04:28 PM
viet1337
May 8, 2007 05:53 PM
2006CiViCsI
Jul 1, 2005 01:02 AM
trashkilla
May 15, 2004 12:37 PM
