B-Series transmission help...
Old May 23, 2005 | 05:32 AM
fabworxs's Avatar
Default B-Series transmission help...
ok, I've got a b-series tranny that I'm trying to rebuild and I do not know the history of it. I'm not sure if its an LS,GSR or Civic Si gearbox. Can anyone help give me some pointers between the 3 that will make one stick out from another. Any help is greatly appreciated!!
Thanks
Old May 23, 2005 | 05:53 AM
b18bturbo's Avatar
Default Re: B-Series transmission help... (fabworxs)
easiest is to count the gears and match it to the specs of each tranny very simple to do
bseries.net had the information along time ago but its no longer posted there
Old May 23, 2005 | 05:54 AM
b18bturbo's Avatar
Default Re: B-Series transmission help... (b18bturbo)
ls uses the 4.2 fd vs the si at 4.4 and the gsr etc at 4.4 so thats one difference and the other is the si and ls use the same ring gear with its own differntial bolt pattern compared to type R or GSR
Old May 23, 2005 | 07:18 AM
fabworxs's Avatar
gotcha. Do you or does anyone know the tooth count on the ring gear??
LS
GSR
SI
Old May 23, 2005 | 08:42 AM
Jared's Avatar
i can tell you that trans is an ls or b16 because of the diff size and carrier bearings
Old May 23, 2005 | 01:35 PM
Big Teggie's Avatar
LS-4.266
Ring Gear=64
Countershaft=15
B16/GSR-4.400
Ring Gear=66
Countershaft=15
jdmfoose
Transmission & Drivetrain
Nov 8, 2013 07:09 PM
Charles B.
Apr 30, 2003 09:35 PM
Dr Drew
Apr 21, 2003 10:48 AM
Turbohatch
Oct 25, 2001 03:27 PM
