Can a b16 head go on a gsr block????
Old May 23, 2005 | 05:31 AM
blowme's Avatar
Default Can a b16 head go on a gsr block????
Basically I'm waiting for my gsr head to be finished, and I was wondering if a b16 head would go on the block without any complications. I have the manifold and head still and cam caps, and I know the combustions chamber is smaller but i didn't know if it could work just to drive for a couple weeks.Another opinion would be appreciated!!
Old May 23, 2005 | 05:56 AM
00Red_SiR's Avatar
All Motor Mentor
Default Re: Can a b16 head go on a gsr block???? (blowme)
The B16 head is the same head as the Type R head minus some light port work. It's combustion chambers are actually slightly larger which would drop your comp ratio by about .2 vs a GSR head. you can use either one you want without problem, do some reading/searching on hear and you'll learn a lot.
Old May 23, 2005 | 06:24 AM
blowme's Avatar
Default Re: Can a b16 head go on a gsr block???? (00Red_SiR)
Thanx man, basically what im doing is putting stage 2 skunk 2s in fully built head but gsr head has crack in it, so i can get a b16 head free, otherwise buy another gsr just trying to get some other opinions on this b/c i want to keep the compression up there you know, i don't want to lose any.
Old May 23, 2005 | 07:55 AM
00Red_SiR's Avatar
All Motor Mentor
Just use a thinner 2 layer head gasket from Cometic or Toda etc and it will compensate for using the b16 head compression wise.
Old May 23, 2005 | 08:33 AM
blowme's Avatar
yea i could do that, are you positive that the chamber is larger??
Old May 23, 2005 | 08:38 AM
00Red_SiR's Avatar
All Motor Mentor
Yes absolutely, do some research and see for yourself.
Old May 23, 2005 | 08:53 AM
blowme's Avatar
Thanx man I appreciate your response, I just read up on some stuff and I think Im just gonna throw my valvetrain into the b16 head and get the head gasket like you said anfter i get my measurements.
Don't they call this setup a poormans type r??
Old May 24, 2005 | 05:37 PM
00Red_SiR's Avatar
All Motor Mentor
yes it can be called that depending on how the B18c block is done up.
hialeahzbg
16
Aug 1, 2006 10:57 PM
0bLiViOuS
Jun 17, 2005 01:10 PM
ninjaturtle1023
Jul 26, 2004 06:32 AM
BI8B
Sep 11, 2003 08:38 AM
Tyson Ballou
Dec 26, 2001 06:17 PM
