Valve adjustment....misfire?
Old May 23, 2005 | 04:58 AM
maxxd97's Avatar
Default Valve adjustment....misfire?
Last year I got a valve adjustment from a friend (an Acura tech) on my B18C. He did it as soon as pulled into his driveway, not allowing the engine to cool down. I said something about it and he kinda brushed it off like it was nothing.
Well, as soon as I got it done, the valves were quiet but there seemed to be a misfire when it warmed up. Now after sitting all winter, it seems to be even worse, but still no noise from the head at all. It only does it at idle, and the car seems to performing well.
Would a bad valve adjustment cause the misfiring?
Old May 23, 2005 | 08:12 PM
sporkcrx's Avatar
Default Re: Valve adjustment....misfire? (maxxd97)
No, but your lash could of been adjusted too tight. Have someone (or you) check the lash when the engine is cold (like in the morning before you drive) and make sure they're within spec.
Jun 15, 2011 12:56 PM
redpeppers
Jul 26, 2005 02:33 PM
d16y8EL
Jan 6, 2004 06:13 AM
XenonDepot
Apr 18, 2003 12:44 AM
ken
Sep 25, 2001 04:06 AM
