Installing custom ITBs. RPM increases very slowly. Why?
I am trying to install these: https://honda-tech.com/zerothread?id=1219616
I finally got the TPS sensor adjusted to around 0.5V closed and 4.5V open now.
When I start it I have to apply a little gas to keep it running until it is warm. If I give it a little gas the rpm only increases slowly. If I floor it, it takes a second or two to get to 3k rpm. It is very sluggish. I doesn't want to rev.
Does anyone know what would cause this behavior? What could be wrong?
Modified by DanishR at 7:27 AM 5/23/2005
Does anyone know if the different injector position could cause this behavior? I don't know how to make this ITB-kit work...
start by looking at the nasic things
is the throttle cable tight or binding
you should have wicked throttle response with any ITB setup
No, I am running a chipped P28. It doesn't change its behavior no matter how I adjust the maps. The car also shakes a bit at idle, but I don't know if that is normal.
You can clearly hear it when you press the gas. It sounds differently, but just doesn't rev much. I can see through datalogging (Uberdata) that it does get the map and TPS signal just fine.
What else could be wrong with it?
No CEL.
I don't remember the values, but at idle it is in column 4-6 or so and at WOT it is in column 9-10. The vacum doesn't seem to be the problem.
well.....what was the cel for? if you want troubleshooting the more info you give the better...
columns 4-6 at idle hugh? thats not right...the ecu could be giving lots of fuel.
do you have a wideband?
Yes, please. I would like some trouble shooting
What info would be helpful?
There is no CEL. I had one earlier. That was because the TPS was not adjusted properly.
With the IM setup I had before it was in column 3-5 at idle.
Yes, I have a wideband hooked up. I have tried to adjust the map but it behaves in the same manner, no mattter what the AF is at. I adjusted it to around 14:1 at one point, but it didn't change anything.
What info would be helpful?There is no CEL. I had one earlier. That was because the TPS was not adjusted properly.
weird....
have you tried playing with timing?
far fetched; but got to try everything you know?
if it really gets down to it i would try using crome with itb tools, wich uses tps for fuel look up.
I haven't adjusted timing much. At one point I changed the vacum values so it idled in column 2-4 instead and without changing the timing values, so in that way I changed timing at idle. Still doesn't wan't to rev. I didn't play around with timing because I read that some people run the stock ECU and a VAFC with ITBs...
It seems to me that something is wrong. It can't be a tuning problem. I have to fix whatever is wrong before I can start tuning it. I just have no idea what to try. The map and TPS sensors work fine. What else could be wrong?
RACEPAK
Aug 27, 2007 02:51 PM
OverCorrupt
Jul 31, 2005 06:22 PM
qstorm
Aug 16, 2004 04:07 PM
