crx b16a code 15
Old May 23, 2005 | 12:22 AM
phatstyles's Avatar
Default crx b16a code 15
I got a code 15. i ran search that is it a dizzy problem. i used the orignal wire hardness from the crx si. so i dont think there should be any wiring problems. CAN anyone help for a solution for this?
Old May 23, 2005 | 12:25 AM
thumbtack's Avatar
Default Re: crx b16a code 15 (prodigyproject)
Ignition output signal.... ignitor or coil... possibly just wiring, but if the car has bee driving fine... more then likely dizzy is shot. Get a known good one and swap it to see if that clears the problem. Dont forget to reset the ecu.
Old May 23, 2005 | 12:46 AM
phatstyles's Avatar
Default Re: crx b16a code 15 (thumbtack)
the car has been driving fine. where do i get a new dizzy at? i used the si wiring harness. why would it be doing that?
Old May 23, 2005 | 12:58 AM
thumbtack's Avatar
well, you have alot of options on where to get a distributor. A brand new OEM Honda one is about 500-700$ from the dealer. Distributor King has them online for about 200-250ish. Get one used on here for around 75-100$. Get one from a Pull-It-Yourself place for like 30$.
Autozone has remans too... they usually suck though. I try to not get anything from Autozone unless it is a last resort type deal. Napa or Autovalue is where I typically get **** from.
Old May 23, 2005 | 01:04 AM
phatstyles's Avatar
Can you further explain. Dont i just need the cap?
Im using my single cam distrbuter plug that goes to the spark plugs could that be it?
Modified by prodigyproject at 9:14 AM 5/23/2005
Old May 23, 2005 | 08:15 AM
phatstyles's Avatar
bump
Old May 23, 2005 | 09:21 AM
phatstyles's Avatar
any1?
Old May 23, 2005 | 10:05 AM
thumbtack's Avatar
no you need to get either a new ignitor or coil. It is inside the dizzy.
Old May 23, 2005 | 11:53 AM
phatstyles's Avatar
when i go to autozone what parts do i buy from what car, i have a obdo wiring.
Old May 23, 2005 | 12:20 PM
EP3_05's Avatar
Your only option for a new OBD0 b16a distributor is distributor king. Otherwise you will need to get a used on or get a 90-91 integra distributor and hack a leg or two off of the body to get it to mount to the b16a head properly. My suggestion is to purchase one from distributor king.
http://www.distributorking.com
Old May 23, 2005 | 01:39 PM
phatstyles's Avatar
Default Re: crx b16a code 15 (91civic)
are there any stores in the USA that actually carry them?
Old May 23, 2005 | 02:00 PM
EP3_05's Avatar
No parts store will carry the OBD0 b16a distributors because there was never a USDM car equipped with an OBD0 b16a.
Old May 23, 2005 | 02:26 PM
phatstyles's Avatar
91 civic very help ful information... thank very much...
is it safe to drive?
Old May 23, 2005 | 02:35 PM
EP3_05's Avatar
It will drive but you will run the risk of being stranded somewhere if the distributor dies.
Old May 23, 2005 | 02:37 PM
phatstyles's Avatar
ahhh i see. is distributor king reliable source? i see there in canada. do they ship right away? its about 300 dollars... i dont want to be stranded!!! lolz
Old May 23, 2005 | 05:17 PM
phatstyles's Avatar
tgh22a
14
May 13, 2006 11:37 AM
Blanket Jackson
Mar 19, 2005 07:42 AM
jonathancrx
Mar 19, 2005 01:33 AM
trexb16
Feb 19, 2004 09:08 AM
Sirex
Dec 8, 2003 09:26 PM
