turbo h22
looking for some advice on a turbo set up. i have a fully built h22 in a civic hatch and want to know what turbo i should get. this a drag car built for tracks use only and what something that will help me get down to 10's 1/4 mile. what size and what brand would be a good one for this set up? what type of turbo are you guys using?
Turbonetics or Garrett. Ball bearing T04.
That'll be the size I use. Or you could go stupid and get a T66
Also, if you don't have them yet, get some cams ground for turbo use to help eliminate the overlap. You'll be much happier.
" What about a T3/T4 B series with a Super V, Stage 3, .63A/R? Are these any good for the H22A engines? This ia what the DRAG kit comes with. "
that sounds soo familiar
it's pretty streetable...
to answer your question, T04X
[Modified by 93H22A, 11:34 AM 2/8/2002]
[Modified by 93H22A, 11:37 AM 2/8/2002]
t3/t4 is what everyone has. it's a smaller turbo and will spool up. I think it's more made for the smaller displacment cars like the 1.6 del slow (minus hocus pocus h22a delsol)
I haven't read much on turboed H22s, but most of the guys in know with turboed hondas in general use a T4, street driven. However, my buddy with a 2000 GSR just installed a T56 turbo. He spins tires just by hitting VTEC in first couple gears and doesn't get as much traction as he would like (he's rolling on 17s and is only running 4lbs of boost so far--has some tuning and small work to be done still). I think he's going for a daily driven 10-12psi...but I'm not sure
he's got a fuly built engine but wants to know what turbo to get. that makes no sense to me. bu whoo gives a DoEs AnYoNe KnOw WheRe I CaN GeT SoMe StRObE LiTEZ AnD LiGhT uP WiNdShiElD NoZzLeS??
any go with a custom set up dawg. soemthing from a dsm. big f-in intercooler. and what nots hondata. to much poo poo to list.
jesse
jesse
i'd go with a full T4 turbo for your "built H22",even for a daily driver.
A T04 is VERY streetable for me. But it all depends on what YOU consider streetable. I was running race gas in every tank, so streetable to me basically is having headlights and a tag.
Like dustin's sig says,
"reliability, fast, cheap... pick two."
A prelude can make 400 hp with a nicely sized T3/T4. Sure a T4 will make more power at 7000 rpms, but the damn thing won't spool until 6500. Bigger isn't always better.
To each his own though.
ok here it is. A T3/T4 will push up to 40psi. That is plenty big enough for an H22. I would go with a revhard race kit. As for 400HP on a turbo h22. You can easily do that on stock internals.
400 whp on stock internals? That's absurd. You'll destroy your ringlands.
But if you click my link it'll take you back to my rice days.
