Very odd suspension noise / vibration
Old May 22, 2005 | 07:55 PM
LSVTEC 91 Civic's Avatar
Banned
Default Very odd suspension noise / vibration
This is strange, it just started tonight.
Sounds like a very bad unbalanced tire, lots of vibration at high speed. I can't pinpoint this noise, because it only makes the noise with the car moving.
The faster I go, the louder the noise gets and the more vibration I have.
Anybody have a problem like this before / know what this could be?
Old May 22, 2005 | 10:10 PM
laosb904's Avatar
sounds like loose lug nuts to me or axle nut came loose
Old May 22, 2005 | 10:47 PM
FalkenSiR's Avatar
Default Re: (laosb904)
Check your tie rod ends. We had this in my dad's car, he ended up getting a whole new rack, but it was definitely the inner+outer tie rod ends. Kinda like what's happening to my car right now... But i think it's part no 10 what causes all these vibrations in EFs.
Old May 22, 2005 | 11:47 PM
31flavorscivic's Avatar
Default Re: (fast88std)
My friend's 4door got creamed in an accident, and we replaced everything affected except the rear hub, and it makes this loud humming noise and a little vibration getting louder as you go. I believe it might be a spun bearing in the hub or something unbalanced in the hub after the accident.
Old May 23, 2005 | 09:18 AM
crxtreme89h's Avatar
Default Re: Very odd suspension noise / vibration (LSVTEC 91 Civic)
This seems to be a common problem lately.
Old May 23, 2005 | 09:59 AM
Tyson's Avatar
Default Re: (31flavorscivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 31flavorscivic &raquo;</TD></TR><TR><TD CLASS="quote">it makes this loud humming noise and a little vibration getting louder as you go. </TD></TR></TABLE>
THAT is the symptom of a bad wheel bearing!
too many ppl call out "check your wheel bearing" for the slightest of suspension noises. but this is the SURE sign of a wheel bearing needing to be changed.
im sick of ppl saying "check your wheel bearing" for every suspension issue.
Old May 23, 2005 | 01:13 PM
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 31flavorscivic &raquo;</TD></TR><TR><TD CLASS="quote">loud humming noise and a little vibration getting louder as you go.</TD></TR></TABLE>
You pretty much described it...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">[/b]
im sick of ppl saying "check your wheel bearing" for every suspension issue. </TD></TR></TABLE>
Old May 23, 2005 | 01:34 PM
shivern's Avatar
Default Re: (LSVTEC 91 Civic)
Yup Yup, remove your whole steering knuckle, the fact you didnt know what it was usually means you wont be able to fix it yourself. Take the steering knuckle to a shop and have them remove the old bearings and press in new ones
Old May 23, 2005 | 01:48 PM
Banned
Now that I know it could be a bad wheel bearing, I did a search and came up with this..
https://honda-tech.com/zerothread?id=419248
Then I found this DIY...
https://honda-tech.com/zerothread?id=720159
I'm going to go and jack my car up later, and see if there is any play in it.
Old May 23, 2005 | 02:20 PM
Banned
I just checked to see if there was any play.
there is VERY LITTLE play (left to right) on my FR wheel, no play when I try to move the wheel up and down.
There is no play on my driver's side.
I guess I'll just drive it and see if it gets any worse.
Old May 27, 2005 | 08:42 PM
Banned
Took another look today.. seems my hub is loose where it bolts to my steering rack..
There seems to be a busted looking ball joint type thing on that steering rack arm?
Seems to be the culprit, there is no other play in the hub..
Old May 28, 2005 | 06:29 PM
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic &raquo;</TD></TR><TR><TD CLASS="quote">Took another look today.. seems my hub is loose where it bolts to my steering rack..
Seems to be the culprit, there is no other play in the hub.. </TD></TR></TABLE>
Would the loose steering rack cause the vibration?
Old May 29, 2005 | 09:29 AM
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic &raquo;</TD></TR><TR><TD CLASS="quote">Would the loose steering rack cause the vibration?</TD></TR></TABLE>
Old May 30, 2005 | 12:38 AM
Tyson's Avatar
yes
Old Jul 24, 2005 | 08:00 PM
Banned
Default Re: (Tyson)
Well, I'm at a loss.
I have absolutely no idea what is going on here.
Loud pulsating noise (maybe sounds like a flat spot in a tire), that increases with speed. Any more opinions?
I'm tired and angry.
Old Jul 25, 2005 | 01:09 AM
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic &raquo;</TD></TR><TR><TD CLASS="quote">Well, I'm at a loss.
I'm tired and angry. </TD></TR></TABLE>
Old Jul 25, 2005 | 06:13 AM
gmptep1's Avatar
any kind of suspenson noise is hard to track down, expesially on these old cars, the sure way to tell is to just replace parts that look worn out. I have owned 5 88-91 EF cars and they are used and abused creatures. If anything looks loose or has damage don't try to just tinker go ahead and replace what ever it is. If you have a flat spot in your tire you will know as soon as you start driving it, it will start a noise then.
Old Jul 25, 2005 | 08:19 AM
Banned
I'm trying to rule out the possiblity of a bad wheel bearing. What does a bad wheel bearing sound like? Is it a metallic grinding noise? If that's the case, then it must be something else.
Old Jul 25, 2005 | 09:34 AM
gmptep1's Avatar
most of the time you can check a wheel bearing by jacking the car up and taking your hands on top and bottom of wheel and check for movement, if it has none then its prolly ok. Rotate wheel and see if there is any grinding or noise besides brake pad rubbing. make sure that all fork radius arm and other bolts are tight, then just check other parts that would give you a vibration in the steering wheel
crxsleeper210
May 22, 2020 02:46 PM
TheNasty0ne
11
Nov 29, 2005 04:58 PM
ef_you
Dec 25, 2004 09:41 PM
DC5_R
Jun 30, 2003 03:35 AM
