clutch switch (need to bypass) please help car not starting
Old May 22, 2005 | 04:48 PM
coot_er's Avatar
Default clutch switch (need to bypass) please help car not starting
Once and a while my car won't start. it doesn't even crank. i think it is the clutch sensor (probably the top one of course ) anyhow is there anyway to test it? were is the easiest place to by pass it? i know one place would obviously be right before the sensor but i don't know if i have any room to reach up there, cut the wires and put them together.
Old May 22, 2005 | 04:57 PM
Humble Performance's Avatar
Default Re: clutch switch (need to bypass) please help car not starting (coot_er)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coot_er &raquo;</TD></TR><TR><TD CLASS="quote">Once and a while my car won't start. it doesn't even crank. i think it is the clutch sensor (probably the top one of course ) anyhow is there anyway to test it? were is the easiest place to by pass it? i know one place would obviously be right before the sensor but i don't know if i have any room to reach up there, cut the wires and put them together.</TD></TR></TABLE>
Unplug it and jump it with a paper clip and if it is bad it should start right up.
Old May 22, 2005 | 05:43 PM
coot_er's Avatar
Default Re: clutch switch (8secEg)
well that sounds easy enough. i looked up there once but didn't see anything, maybe i just need to look harder?
if anyone has a pic (of the clip so i know what im dealing with) it would be greatly appreciated
Old May 22, 2005 | 07:37 PM
Default Re: clutch switch (coot_er)
Just follow te clutch pedal towards the upper back part , there should be like a yellow sensor. Just unplug it and jump the wires with a paper clip , it is easy.
91H4hatch
Jan 16, 2008 01:16 PM
yaleforizzle
Dec 8, 2003 06:34 AM
p0pe
Sep 20, 2003 07:52 PM
p0pe
Sep 19, 2003 09:53 AM
95gsr
Audio / Security / Video
Feb 5, 2002 04:47 AM
