possible compressor bearing noise?
Old May 22, 2005 | 01:53 PM
wahee's Avatar
Default possible compressor bearing noise?
hi - I have a high pitched rattle and a low drone - sort of 'dead bearings' drone
Its at the crank pulley end.
Just done a search and it may be water pump noise. Anything else it could be?
The noise rises with the revs
The car is a 1990 genuine JDM si (zc) with 50k miles on it - timing belt was done 5000 miles ago and looks in good condition.
Am I right in thinking that if I loosen the AC idle pulley I can remove the belt & see if the noise is still there. Basically to eliminate the compressor from my 'noise hunt'
Can the compressor be reconditioned?
many thanks
Alan
the soL that could
Aug 15, 2011 02:54 PM
James
Apr 25, 2007 06:17 PM
ironryder
Jul 13, 2005 07:07 PM
wragen22
Apr 18, 2005 12:53 PM
Drew96EJ
Oct 6, 2004 05:52 PM
