FS: B18A1 Block and AVC-R boost controller avcr *pics*
AVCR sold
open to offers on both...
Block
B18A1 Block, p30 B16a pistons, micropolished crank, new main bearings, new rod bearings, new thrust washers, new piston rings, new front and rear seals, new type r vtec oil pump, new vtec water pump, coolant passage, thermostat housing, oil pressure sensor, oil catch can, crank pulley, block is very clean
Avcr was purchased from import-palace last year, used for about a month... comes with everything as if you were to buy it brand new
Modified by B18 CYA at 9:32 PM 5/26/2005
Block
B18 CYA
Jun 7, 2005 06:12 PM
