i just bought an integra and need help
Old May 22, 2005 | 10:36 AM
newintegraowner's Avatar
Default i just bought an integra and need help
i just bought a 97 integra and i need some help fixing it. i can not figure out what is wrong with it. it has the b18b1 engine and the first cylinder has about 30 lbs per cubic inch less compersion than the other cylinders and a loud tapping noise coming out of the first cylinder, i was wondering if anybody had any ideas of what that could be.
Old May 22, 2005 | 10:57 AM
DAguyLS's Avatar
could need a valve adjustment
Old May 22, 2005 | 11:00 AM
Uncle Ben's's Avatar
Cogent Argument Enthusiast
Default Re: (DAguyLS)
could be the piston rings. try putting oil in the cylinder then do it. if the compression is normal after you pour oil into the cylinder, then its the piston rings.
Old May 22, 2005 | 02:20 PM
Sam92Teg's Avatar
Default Re: (benb18a)
Or the previous owner had a slight hydro-lock situation, lets hope not.
Old May 24, 2005 | 02:45 PM
Default Re: (Sam92Teg)
what is a hydro-lock situation? never heard of it, is it serious?
Old May 24, 2005 | 03:05 PM
Lavisracing's Avatar
Default Re: i just bought an integra and need help (newintegraowner)
I would bet more on either the valves or piston rings is there any type of smoke coming from the exaust?
Old May 24, 2005 | 07:19 PM
korean_teg's Avatar
Did you buy the car knowing it had this problem? I hope not. Mind telling us how much you paid?
Old May 25, 2005 | 12:27 PM
Default Re: i just bought an integra and need help (korean_teg)
there is no smoke coming out of the exhaust and i did buy it knowing there was a problem but i test drove it and a machanic was with me, i felt no it had no power loss and he said that the tap sounded like it was not internal, something like a wire in the alternater, so i bought the car, i got it home and had someone take a second look at it and they said it was internal , i checked almost everything that it could be external and that is where i am now, i paid 1800 for it. i think it was still worth it.
Old May 25, 2005 | 12:53 PM
RenzoDaPlayboi's Avatar
1800 for a 97 damn thats good as hell
Old May 25, 2005 | 02:15 PM
Default Re: (RenzoDaPlayboi)
its not to bad
Old Dec 20, 2006 | 03:52 PM
GODSPEED33's Avatar
Default Re: (newintegraowner)
ya im having kinda same problem tapping no smoke i ajusted valves im going to change the timming belt this week end but i payed $400 for my 97
Old Dec 20, 2006 | 05:12 PM
bildo16's Avatar
Hmmmmmm. You are probably going to have to pull off your head. It could possibly be bent valve. Pull of your PCV line off the back of your valve cover and see if it is pushing a good amount of air out of it, if so, your rings may be junk.
Old Dec 20, 2006 | 05:26 PM
B204door's Avatar
Default Re: (bildo16)
Im having same exact problem. i had a lot of opinions on wat it culd be, rods, pistons, valves, valve adjustment, I had another friend of mine look at it today and he told me to get the valves adjusted and if it doesnt go away then most likely i have a bent valve and to replace them. lol thats weird cuz i bought a 91 teg knowing it had a tapping noise. i paid 900 for it so i wasnt too upset cuz i think i can fix this. let me no if u get it fixed and wat u did and i'll let u no as well.
soulo
Apr 25, 2009 08:58 AM
killingtwobirds
Aug 28, 2007 07:24 PM
jennsGSR
Aug 17, 2006 06:12 PM
SiRkid
Jan 4, 2005 06:34 PM
