Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Oil coolers re-visited
Old Feb 6, 2002 | 08:46 AM
celica73's Avatar
New User
Default Oil coolers re-visited
Well, not long ago we had a thread about oil coolers. I wanted to hear what yall think about this one.
This is a Toyota/TRD unit for the 7th gen Celica (or so they say). It sandwiches between the oil filter and the engine block, and there are already place to run the water lines in the Celica (some capped lines on the US cars). This may even be a stock item in Japan.
The question is, in a small heat exchanger like this, how much cooling would you expect (now the coolant/radiator is taking the thermal load, rather than a separate heat exchanger).
Anyone have a clue as to how well this might work? Other comments?
Scott
'00 Celica GTS
'73 Celica ST
Old Feb 6, 2002 | 09:23 AM
Willard's Avatar
Default Re: Oil coolers re-visited (celica73)
Better than nothing
Helps warm the oil up and will stabilize the temps (oil and water) when the car sitting still.
Not sure how well the unit will work under heavy thermal load.
Similar to the stock ITR unit.
Will
Old Feb 6, 2002 | 09:34 AM
typer_801's Avatar
VW's have had those since 84 and the biggest problem was they tended to fail and mix oil and coolant. Not good for either system The primary benefit is obviously cooler oil, but it's not very powerful so don't expect much. As noted, it also warms oil too in cold conditions. A very mediocre oil cooler setup in the grand scheme of things.
Old Feb 6, 2002 | 10:02 AM
celica73's Avatar
New User
Default Re: Oil coolers re-visited (typer_801)
Those are the answers I was hoping to get. I wasn't aware that the ITR or the VW's had a similar item.
I doubt it will be worth the overprice that TRD will want for it, not when I can do the real thing for less money and have it work better.
Thanks
Scott
Old Feb 6, 2002 | 10:08 AM
Honda318dx's Avatar
Default Re: Oil coolers re-visited (Willard)
Will
Similar to the stock prelude unit as well...
Old Feb 6, 2002 | 11:30 AM
Knightsport's Avatar
El Chico
25 Year Member
Community Builder
Community Influencer
Default Re: Oil coolers re-visited (Honda318dx)
I would just go with an aftermarket oil cooler that has a tube/fin design. It's far supperior to the little TRD units.
Old Feb 6, 2002 | 03:26 PM
DB2-R81's Avatar
25 Year Member
Default Re: Oil coolers re-visited (Knightsport)
If your going to spend money why not get one of these. Good enough for McLaren's should be good enough for your car.
http://www.laminova.se/products/indexprod.htm
[Modified by DB1-R81, 4:30 PM 2/6/2002]
Old Feb 6, 2002 | 05:51 PM
GSRMatt's Avatar
25 Year Member
Default Re: Oil coolers re-visited (DB1-R81)
I detest sandwich adapters. Had a nightmare with my factory Talon one. If at all possible, spend a few bucks more and isolate the two systems.
longshot
11
Jan 23, 2009 10:56 AM
Dan GSR
15
Feb 4, 2004 02:11 PM
celica73
Nov 24, 2002 05:34 PM
Chubz
May 31, 2002 02:06 PM
onyx00
Nov 13, 2001 05:52 PM
