redline?
Old May 22, 2005 | 07:49 AM
jayare05's Avatar
Default redline?
my buddy just recently put a tach in his 95 4 door civic dx which didnt orginally come with a tach. anyone know what the car redlines at? engine code is d15y7 i believe
Old May 22, 2005 | 07:51 AM
Deemeetree's Avatar
Electrician
1992-1995 DX/LX are D15B7
1992-1995 EX/Si are D16Z6
1992-1995 CX are D15B8
1992-1995 VX are D15Z1
D15B7 redline is at 6,400 RPM. Cut-off should be at 6,800 RPM.
Old May 22, 2005 | 07:57 AM
jayare05's Avatar
Default Re: (Dimitri_EG8 a.k.a. Dimi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimitri_EG8 a.k.a. Dimi &raquo;</TD></TR><TR><TD CLASS="quote">1992-1995 DX/LX are D15B7
D15B7 redline is at 6,400 RPM. Cut-off should be at 6,800 RPM.</TD></TR></TABLE>
then it must be d15b7.. we tapped into every dizzy wire there was and its redlinin at 3500 rpm's? why is this? there isnt any other dizzy wire to tap into?
Old May 22, 2005 | 08:03 AM
Deemeetree's Avatar
Electrician
Do not tap into distributor wires.
Behind the driver side strut tower is a harness. Look at it. You'll see a single blue wire hanging there (or under the tape) with a black rubber grommet looking piece at the end of it. It won't be bundled in the harness, it will be just dangling there seperated from the rest. That carries an RPM signal. Tap into there for the RPM signal.
sky9
21
Feb 2, 2007 09:23 PM
EARLdaSQUIRREL
13
Jan 23, 2003 07:05 PM
Freelance-GSR
Dec 11, 2002 01:18 AM
drkblue_civic
11
Nov 22, 2002 01:51 PM
batboy18
Sep 4, 2001 12:41 PM
