auto to manaul question
Old May 22, 2005 | 07:16 AM
beastda9's Avatar
Default auto to manaul question
I have a 94 ex coupe with 60k miles on the motor and the automatic tranny and i was thinking about doing a auto to manual conversion. I was wondering what were the pro and the cons of doing the conversion.
Old May 22, 2005 | 07:22 AM
JDM-EJ1's Avatar
Default Re: auto to manaul question (beasteg94)
There is a lot of work involved with this, I'm in the process of doing the swap myself. There are a lot of needed parts. The pros obviously outweigh the cons. Manuals are easier to work on, you get better gas mileage, are cheaper to maintain.
These are the parts you'll need..
Tranny
ECU (manual ECU for your motor)
Starter
Clutch/Flywheel
Shift Linkage
Shifter
Shift ****
Console
Clutch Resovir
Slave Cylindar
Clutch Cylindar
Mount (NOT AN OEM MANUAL MOUNT, unless you want to weld)
Ped Assembly
That's all I can think of, I know I'm porbably missing something.
Old May 22, 2005 | 05:09 PM
beastda9's Avatar
Default Re: auto to manaul question (JDM-EJ1)
this might be another stupid question but about how much would all the parts cost to perform an auto to manual conversion?
Old May 22, 2005 | 06:35 PM
Formsim's Avatar
i completed the auto - manual swap , i think its more time consuming than cost myself,
don't forget your gonna need
clutch lines
shifter bushings
chassis shifter cover (don't want huge holes where the automatice use to be)
gear oil
manual axles (size is diffrent)
as for that tranny mount
i picked up a after market tranny mount built for auto to manual conversions for $75 of ebay, i don't think its listed anymore but i know the shop that makes them if u want one.
as for the tranny, i had 2, first was lx tranny and had worn synchro's and poped out of 3rd and 5th (if u got the money to rebuild the tranny before installing i would suggest it) so i switched it to a same year ex tranny, much better gear ratio for quicker acceleration. try to pick up a ex/si tranny if u can
cost me somewhere between $7-850 not including labor
if your gonna do it yourself be prepaired for a good amount of work
Old May 22, 2005 | 06:44 PM
Otherguy's Avatar
NASIOC.com
Default Re: auto to manaul question (Formsim)
i did it on my friends car... its easy to do if you know what your doing... just take your time and dont take short cuts... i took the whole motor out did the work that needed to be done to the car with out the motor in. Other then that it was simple
Old May 22, 2005 | 06:48 PM
Status Sean's Avatar
Default Re: auto to manaul question (Otherguy)
if u know what your doing its worth it !
Old Jun 4, 2005 | 07:28 AM
beastda9's Avatar
Default Re: auto to manaul question (rw92civic)
i want to do a b16 swap eventually as well should i wait and do the conversion and the swap at the same time?
Jackie Wallace
Transmission & Drivetrain
Mar 10, 2013 04:23 PM
OuToFoCuZ
23
Dec 1, 2006 11:02 AM
danwants2btheman
Sep 13, 2006 12:33 PM
tegra33
Sep 23, 2004 08:07 PM
Banned Poser
Feb 6, 2004 09:30 PM
