type s cams
Old May 22, 2005 | 05:32 AM
st3alth's Avatar
Default type s cams
are these much better than the normal ones for 5th Gen prelude?? anyone got proper specs on these also?
Modified by [ S7H ] at 7:11 AM 5/22/2005
Old May 22, 2005 | 06:10 AM
st3alth's Avatar
also how can u tell if theyre the genuine item.. here are pics of cams + headers from a type s.. this I was told..
Old May 22, 2005 | 06:26 AM
TurboSam's Avatar
Default Re: type s cams ([ S7H ])
the cams might give u an extra 5hp, i personally never used them but thats a rough guess. its nearly impssible to tell from pics like that, you pretty much have to check them with a micrometer the be sure.
Old May 22, 2005 | 06:33 AM
st3alth's Avatar
so cams + headers? 10hp perhaps? hehe
Old May 22, 2005 | 06:49 AM
TurboSam's Avatar
Default Re: ([ S7H ])
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by [ S7H &raquo;</TD></TR><TR><TD CLASS="quote">]so cams + headers? 10hp perhaps? hehe </TD></TR></TABLE>
maybe, i wouldnt get too anxious though. the type s also has higher compression. higher compression alone makes power, then combine it with a higher lift cam, and the extra compression makes the cam more efficient, etc. i think you get the idea.
my guess is you wont gain much with those mods alone, but combined with an intake and a maybe a good vafc tune you should see better results
Old May 22, 2005 | 06:54 AM
st3alth's Avatar
yeah looking to perhaps get these cams + headers plus
- ICEMAN CAI (on the way)
- ECU chipped/tuned/dyno
- Spoon Head Gasket
- Hi-flo Cat
- New Cat-back exhaust
should get some power then ye?
Modified by [ S7H ] at 8:11 AM 5/22/2005
Old May 22, 2005 | 11:12 AM
machine4321's Avatar
lots of people have seen 200whp with type s cams ...id rather have thme the any stage 1 cam out there(skunk crower ect)
Old May 22, 2005 | 11:51 AM
mgags7's Avatar
what about rockets vs the type s cams....that graph on kteller is amazing....
Old May 22, 2005 | 01:14 PM
PirateMcFred's Avatar
I made over 200whp on type-s cams and a header... but I can't tell if the header and cams will get you there judging by your pictures. Get a micrometer and measure the VTEC lobe and PM me I can tell you if they are or not.
Pirate
Old May 22, 2005 | 01:41 PM
xbn83's Avatar
Default Re: type s cams (PirateMcFred)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PirateMcFred &raquo;</TD></TR><TR><TD CLASS="quote">I made over 200whp on type-s cams and a header... but I can't tell if the header and cams will get you there judging by your pictures. Get a micrometer and measure the VTEC lobe and PM me I can tell you if they are or not.
Pirate
I just dropped a set of Type S cams, adj cam gears last week. Cam gears are all at 0. I 'm having an untuned VAFC but still feel noticable gain. I 'm waiting for my catback, hi flow cat, and then hit the dyno. I hope I will make around 200whp along with other mods. Wish me luck! And good luck to you too S7H.
Old May 22, 2005 | 01:57 PM
Default Re: type s cams (xbn83)
I hope you have a *good* header... It took me a lot of tuning to get 200whp. I hope your VAFC is adequate.
Pirate
Old May 22, 2005 | 02:03 PM
xbn83's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PirateMcFred &raquo;</TD></TR><TR><TD CLASS="quote">I hope you have a *good* header... It took me a lot of tuning to get 200whp. I hope your VAFC is adequate.
Pirate</TD></TR></TABLE>
I believe you. I don't have a good header. I have a shitty DC, plan to wrap it soon with Thermotec. I dyno tuned my VAFC before when my car was still an auto with fewer mods than now, I gained 9whp and some area near the top I gained the largest of 14whp. I think VAFC for now is ok not too bad.
Old May 22, 2005 | 03:17 PM
LostAndFound's Avatar
what was the rest of your setup pirate. just wondering what you had to do to get to 200whp. cams and bolt ons?
Old May 22, 2005 | 03:30 PM
st3alth's Avatar
Default Re: (LostAndFound)
Markings are a J and a K on either cam....
HiCam lobe size is 36.85mm or 1.45 inches...
Old May 23, 2005 | 07:41 AM
MartBB6's Avatar
Hi PirateMcFred,
I have the current engine setup:
- Mugen header
- Greddy evo I exhaust
- Magnaflow hi flow cat
- Type S intake
- VAFC II (untuned yet)
Do you think that adding a set of used type S cams can get me to the 200 WHP (and tuning) ?
Thanx
Mart
Old May 23, 2005 | 03:00 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xbn83 &raquo;</TD></TR><TR><TD CLASS="quote">
I believe you. I don't have a good header. I have a shitty DC, plan to wrap it soon with Thermotec. I dyno tuned my VAFC before when my car was still an auto with fewer mods than now, I gained 9whp and some area near the top I gained the largest of 14whp. I think VAFC for now is ok not too bad.</TD></TR></TABLE>
All OEM H22 except inner springs and retainers for a little insurance in case of over-rev, adj cam gears and a custom header/2.25" exhaust (that could have been better).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MartBB6 &raquo;</TD></TR><TR><TD CLASS="quote">Hi PirateMcFred,
- Mugen header
- Type S intake
Not real likely but you never know you could have a strong motor. It's all in the tuning and a VAFC is not real high on the list of great tuning devices.
It's all in the tune guys...
Pirate
espnews
Jan 4, 2008 09:02 AM
Cidone
Nov 19, 2006 02:22 PM
pr0jektezek1el9
May 2, 2004 07:31 PM
Ninjames
Feb 7, 2004 04:20 PM
Trbospnkr
Jul 16, 2003 04:53 PM
