Car hesitates whats wrong?
Old May 21, 2005 | 09:23 PM
(__________)'s Avatar
Default Car hesitates whats wrong?
Driving in 3rd, 4th, or 5th gear around 3-3.5k my car kind of hesitates then it goes. It only does it every so often but I want to get is solved before its constant. My car is coming up on 90k. It has new plugs and wires, I am thinking maybe its time for cap and rotor?
Old May 21, 2005 | 09:34 PM
Chris F's Avatar
Default Re: Car hesitates whats wrong? (steves98itr247)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steves98itr247 &raquo;</TD></TR><TR><TD CLASS="quote"> It has new plugs and wires, I am thinking maybe its time for cap and rotor?</TD></TR></TABLE>
Sounds like a good plan. Does it do it mostly at full throttle?
Old May 22, 2005 | 05:36 AM
Default Re: Car hesitates whats wrong? (Chris F)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">
Sounds like a good plan. Does it do it mostly at full throttle?</TD></TR></TABLE>
It doesnt do it at all during full throttle, it only does it every so often when I am cruising around town when I go to tap the gas.
Old May 22, 2005 | 07:09 AM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
ignition problem
plugs, cap, rotor,
Old May 22, 2005 | 07:29 AM
Dubber's Avatar
could also be tps...but i dont think it would be that when youre just coming up on 90k...so its probably an ignition tuneup you need
Old May 22, 2005 | 09:40 AM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steves98itr247 &raquo;</TD></TR><TR><TD CLASS="quote">It doesnt do it at all during full throttle, it only does it every so often when I am cruising around town when I go to tap the gas. </TD></TR></TABLE>
Ooh, hmm... Yeah, what Dubber said, TPS could be it! Too bad you don't have a code to work with . You could use a voltmeter to see if it's a nice smooth sweep from ~0V to ~4.9V (I think that's what Hondas are, not sure). If it jumps somewhere, probably in light/part throttle, that could do it.
-Chris
Old May 22, 2005 | 10:11 AM
Im thinking its time for cap and rotor, Ill do that then work from there
Old May 22, 2005 | 04:29 PM
MackDad's Avatar
When was the last time you replaced your fuel filter?
Old May 22, 2005 | 04:50 PM
RTW DC2R's Avatar
-Chris
hmmm care to elaborate a bit more on how the TPS works? I had this same exact problem a long time ago on a B16 and replaced the usual ignition and fuel stuff but it never really got much better and never diagnosed it. Im now wondering if it was related to the TPS.
Old May 22, 2005 | 04:58 PM
Chris F's Avatar
Default Re: Car hesitates whats wrong? (RTW)
Throttle posision sensor is like a potentiometer... It does a pretty linear sweep of voltage (0-5V, or .7 to 4.2, or whatever) so that the ECU can correct fuel even before the MAP reads a pressure difference. Etc.
http://www.off-road.com/toyota/tech/tps/
"Symptoms of a bad or mis-adjusted TPS include variying idle speed, hesitation while accelerating, poor fuel economy, and inabiltiy to correctly set base ignition timing."
So, if the TPS wasn't reading the right voltage, you might get a hesitation when you tip-in on the throttle.
I had a CEL for a TPS once, on a Cavalier, and the symptom was bizarre drivability (super bad hesitation, etc.) because the ECU had no idea how fast the throttle was being opened. The TPS code caused the ECU to ignore the TPS altogether and that was the result. It was due to a bad adjustment. ()
More details googled here..
http://www.autoshop101.com/forms/h33.pdf
Old May 22, 2005 | 06:33 PM
Im going to Acura tomorrow to get my cap and rotor if that doesnt do it then im going to wait to get back to the expo and im going to do my TPS. I changed my fuel filter at 75k, so it still should be good.
Old May 22, 2005 | 06:34 PM
RTW DC2R's Avatar
awesome TPS explanation, Chris thx
stdefhatch
Mar 5, 2008 05:58 AM
rice a roni
Mar 23, 2006 12:37 PM
JoshuaVTEC
11
Jul 24, 2004 04:45 PM
J's 94 Accord
Mar 31, 2004 08:43 PM
9deuce9rr
Feb 11, 2004 02:49 PM
