Who said hiding the fusebox was alot of work....
Old May 21, 2005 | 05:05 PM
_Spugen_'s Avatar
Default Who said hiding the fusebox was alot of work....
Well it is...Mainly alot of thinking how you are going to route the wires...Took me a good three to four hours to hide it...Only two wires were extended..
Bottom of the box where the harnesses plug into...Unplug them..
Take all the tape, loom, and misc. stock **** off the wires...Run them into the existing plug...
Get into the interior and remove glovebox to work easier, pull carpet back, and reach up and feel where the stock harness goes through. Rip off some of the foam **** so the wires go in easier....Going biggest to smallest gently push the harness plugs that where underneath the fusebox into the hole...this part is timing consuming to me atleast...
They should appear here...
I extended the two tires that come from the starter and the main power supply cause they were a tad bit short and I didnt want to force em...
Finally bend the braket a bit with some pliers or something and simply bolt it down to the existing hole...
Next is extending the passenger headlight wires to hide them, I already did the drivers side...This crap sucks...
Old May 21, 2005 | 05:06 PM
Motor-Tek's Avatar
maybe a dumb question, but why hide it? Clean up the engine bay or for security purposes?
Old May 21, 2005 | 05:08 PM
_Spugen_'s Avatar
Mainly to clean up the engine bay a bit...
Old May 21, 2005 | 05:11 PM
PhantomEG's Avatar
Default Re: (Spugen_y0)
Show some bay pics so we can see the diffrence...like farther away pics...Thanks...Good work i might have to try...
Old May 21, 2005 | 05:43 PM
markwitdada9
Guest
Posts: n/a
Default Re: (PhantomEG)
Old May 21, 2005 | 07:06 PM
FlatBrokeHatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhantomEG &raquo;</TD></TR><TR><TD CLASS="quote">Show some bay pics so we can see the diffrence...like farther away pics </TD></TR></TABLE>
Old May 21, 2005 | 08:34 PM
Mires's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhantomEG &raquo;</TD></TR><TR><TD CLASS="quote">Show some bay pics so we can see the diffrence...like farther away pics...Thanks...Good work i might have to try... </TD></TR></TABLE>
Old May 21, 2005 | 08:42 PM
_Spugen_'s Avatar
Im not quite done yet....Still extending passenger side headlight harness and Still have to tie/cover all the wires. Then Ill clean it up a bit, I should be done tommorow..
Old May 21, 2005 | 09:01 PM
BolivianDc2's Avatar
Default Re: Who said hiding the fusebox was alot of work.... (Spugen_y0)
looks good
now get rid of those AC lines
Old May 21, 2005 | 10:15 PM
jbell's Avatar
be careful doing the headlight harnesses and such on the del sol. i just did mine, and i confused the aux and horn plugs (they are the same) lets just say my fog light were very... loud.
Old May 21, 2005 | 10:27 PM
VTEC_Club's Avatar
Default Re: (jbell)
I was gonna go that too but I gave up after I looked under the dash. Good write up
Old May 22, 2005 | 07:33 AM
_Spugen_'s Avatar
Default Re: (jbell)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jbell &raquo;</TD></TR><TR><TD CLASS="quote">be careful doing the headlight harnesses and such on the del sol. i just did mine, and i confused the aux and horn plugs (they are the same) lets just say my fog light were very... loud. </TD></TR></TABLE>
Yea I learned that lol...But I dont have fogs so owell....
Just getting started again...
Alex V
Jul 5, 2019 10:46 AM
SAMCRO08
14
Jul 12, 2012 05:55 PM
K2e2vin
May 17, 2006 04:52 PM
timmy0tool
Mar 28, 2006 11:09 AM
Thanks knightsport!
Feb 6, 2006 08:38 AM
