Headlight Restoration Kits / Methods ????
Hey guys, im looking to restore the outside of my G3 integra headlights which are dinged, scrached and a little hazy. anyway, i have seen headlight restore kits before and i also know that you can wet sand them the clear them up again to, but having done neither of those before, i was hoping sombody could tell me about a kit or a method they used that worked really well for clearing up thier beat up headlights. i have used neverdull on them before to, and they are beyond what neverdull can do. anyway, any advise would be greatly appreciated. thanks.
i just wetsanded with 800 grit to take off the clearcoat type protective film then i used 2000 grit and used 3m plastic polisher
i used 800 grit sandpaper, take a 20 oz bottle of water, and sand while pouring water down, sand till you see a white film, then move on to the next light......repeat once more to clean everything out, then either buff out your lights with a dremel with a buffing pad, or use a good metal polish
my method: est time: 1 hour
good luck!
good luck!
