CEL 41 - Primary Heated O2 Sensor
Old May 21, 2005 | 03:29 PM
-Bionic-'s Avatar
Former Sponsor
Default CEL 41 - Primary Heated O2 Sensor
I have a 99 accord with a OBDI H22.
About a month ago, I received a cel 41. Because I have about 130K miles on the O2 sensor, I figured that the sensor was going bad, and that it was time to replace it.
Today, I replaced the sensor with a Honda OEM, but the code is still there, and I have also tried to disconnect the battery.
I have also measured the resistance between the black wires, and it's somewhere between 30-40 ohms. Further, there is no continuity from either wire to the ground.
Any help is much appreciated.
Old May 22, 2005 | 04:52 AM
Chiovnidca's Avatar
Default Re: CEL 41 - Primary Heated O2 Sensor (-Bionic-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -Bionic- &raquo;</TD></TR><TR><TD CLASS="quote">
Maybe it's a wiring problem. Have you checked the wires for continuity back to the ECU? Connector pin fit can cause problems too.
Old May 22, 2005 | 09:15 AM
-Bionic-'s Avatar
Former Sponsor
Default Re: CEL 41 - Primary Heated O2 Sensor (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">
Maybe it's a wiring problem. Have you checked the wires for continuity back to the ECU? Connector pin fit can cause problems too.</TD></TR></TABLE>
Thank you very much for the reply.
Should I check all of the wires [part of the main harness] for continuity? I already checked the wires for the O2 sensor for continuity, but neither had any. To my understanding they wren't supposed to either.
Thanks
bobcollege
15
Mar 22, 2018 10:12 PM
Senior Taco
Jan 28, 2010 02:52 PM
gsrcivic619
14
Dec 21, 2007 03:35 PM
team 15
Feb 20, 2007 08:29 PM
-Bionic-
May 24, 2005 11:29 AM
