Car had problems starting and tach+speedo jumping
Old May 21, 2005 | 01:21 PM
SOHC_MShue's Avatar
Default Car had problems starting and tach+speedo jumping
Today I took my car to my friend who work's at Acura to get an alignment done. The car ran great before i got there, but after he was done we went to start the car and it wouldn't start up. He jumped my battery and it started fine, but once i got it on the road the tach+speedo were jumping all over like crazy. After a couple of minutes they were back to normal again. Any idea whats going on? Sounds like maybe my alternator is bad?
Old May 21, 2005 | 01:40 PM
SOHC_MShue's Avatar
Default Re: Car had problems starting and tach+speedo jumping (SOHC_MShue)
yea i checked the voltage on my wideband and its lower than normal + my car won't start again.
Old May 21, 2005 | 01:42 PM
The Internet Tough Guy's Avatar
check your grounds ... one time my speedometer was bouncing all over the place. one of the grounds was loose.
Old May 21, 2005 | 01:43 PM
SOHC_MShue's Avatar
Default Re: Car had problems starting and tach+speedo jumping (The Internet Tough Guy)
did it also cause the car to not start and the battery to have low voltage?
Old May 21, 2005 | 01:52 PM
no but it can cause that
bad ground = crazy ****
i'm not saying it IS the problem, but it's definately something you should check.
Old May 21, 2005 | 01:57 PM
SOHC_MShue's Avatar
well i went to take off one of the wires on the alternator and when i was trying to loosen the nut it was stuck on the stud and the stud broke in half
Modified by SOHC_MShue at 7:08 PM 5/21/2005
Old May 21, 2005 | 03:08 PM
SOHC_MShue's Avatar
bump
Old May 21, 2005 | 04:53 PM
SOHC_MShue's Avatar
up
Old May 21, 2005 | 04:57 PM
civicboisi's Avatar
usually when we align vehicles, we use a brake rod to press the brake pedal down during the alignment...chances are, they may have took too long while aligning it, causing the battery to go dead or something...
happens to us once in awhile...but the speedo/tach shouldn't jump irratically...sounds like wiring or ground issues as stated above.
Old May 21, 2005 | 05:17 PM
SOHC_MShue's Avatar
Default Re: Car had problems starting and tach+speedo jumping (civicboisi)
well the speedo and tach calmed down and went back to normal after a few minutes of driving. My battery still wasn't charged after the drive like it should have been though. After letting the car sit for 10 minutes it wouldn't start back up again. thats why i'm guessing its the alternator.
Old May 22, 2005 | 09:35 AM
SOHC_MShue's Avatar
bump for help
Old Nov 21, 2006 | 06:36 PM
pyitrboy's Avatar
use your multimeter and probe the positive and negative terminals while the
car is running...should have about 14.3 volts.
If you don't and are getting 12 volts, the battery is not getting charged and the alt.
is the problem
d_EG COUPE
Oct 31, 2009 02:48 PM
SOKDO
Jun 2, 2005 10:33 AM
BeavisB16
Sep 18, 2003 06:08 AM
alfaaay
Aug 15, 2003 01:47 PM
94HybridEX
Oct 10, 2002 10:06 AM
