stock steering wheel install
i have had my jdm 5zigen wheel on for a while now and i am going to take it off and swap it on my civic, just cant remember how to put the old one back on, its a stock gsr wheel with srs, pics would help!!
Unplug negative terminal off battery. Take the steering hub off. Feed the horn and SRS wires from cable reel through the GSR outer wheel. Plug up the horn wires. Bolt the outer wheel to the spindle. Screw in the airbag. Connect SRS plugs. Reconnect battery and reset SRS light.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">Unplug negative terminal off battery. Take the steering hub off. Feed the horn and SRS wires from cable reel through the GSR outer wheel. Plug up the horn wires. Bolt the outer wheel to the spindle. Screw in the airbag. Connect SRS plugs. Reconnect battery and reset SRS light.</TD></TR></TABLE>
How do you reset the SRS light??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-CeReaL#4 »</TD></TR><TR><TD CLASS="quote">shoot it with a gun</TD></TR></TABLE>
LOL,, that solves everything
Bloody Hatch
Jan 28, 2009 07:27 AM
spooneg8
Dec 18, 2006 12:58 AM
