Rocket Motorsports KTeller Spec'd H22 H22a Cams and Valvetrain Dyno
Old May 21, 2005 | 10:39 AM
Adam.'s Avatar
Default Rocket Motorsports KTeller Spec'd H22 H22a Cams and Valvetrain Dyno
Update: 6/25/2005 Tuned
Update: 6/7/2005 Tuning Session scheduled for 6/25/2005
Update: 6/4/2005 Cam and valvetrain install completed
Update: 5/29/2005 Baseline dyno before cam install at the bottom of this post
I have seen at least 20 threads where people are looking for dyno's on a good setup, not jdogg's bent valve mess . This thread is for anyone that actually has a dyno to post up.
I just got in my parts recently, here are some teaser pics. I am currently swapping my h22 out of my ek into an eg so I won't be getting dynos until around mid-late june hopefully sooner.
<U>My Setup thus far (well, the parts that make power anyway): </U>
Fake J's Racing Intake w/ K&N Filter
EuroR Intake Manifold
Hondata IM Gasket
Balance Shaft Belt Removed
AN-R Header with 2.5" Street Collecter
Mandrel Bent KTeller Exhaust 2.5"
Magnaflow ES Oval Style Muffler 2.5"
Tuned via Uberdata or Crome
Update: 5/29/2005
Baseline, everything above and a street tune. Max torque is down simply b/c of a tuning issue around VTEC crossover. Just to repeat in case you get confused.
THIS GRAPH IS NOT WITH THE ROCKET MOTORSPORTS H22 REGRINDS. IT IS A BASELINE FROM 5/29/2005.
<U>What's Going on the car:</U>
Kteller Spec'd H22 Regrinds - 240 duration at 0.050 and 11.5mm lift for both in/ex
R/M Springs & Retainers
Skunk2 H22 Cam Gears
Stock Throttle Body overbored to 66mm with Taper
<U>Notes:</U>
Engine still has stock compression of 10.6:1
The head is untouched
The block is untouched
Around 60,000 Miles on the motor
Update: 6/27/2005
Well I got some numbers. They aren't great numbers, but they are good numbers. I can tell you this much and I saw it for myself, it was hard to get these things to budge from the baseline.
Ending cam timing was +2, -1 as I picked up the most torque from it.
I'll explain the biggest things first. Obvious things first, these cams made no substantial gains in power over my jdm cams. I did pick up some midrange, but if you compare that to my original dyno, it was a baseline w/ no tuning. I spent three hours on the dyno and pretty much got disappointed the entire time. Pay no attention to the AFR on the graph as it didn't always read correctly.
You'll notice I have two lines there, one is with VTEC @ 3500 the other is at 5100. The reason I put this up is b/c the primaries would not carry any power at all. The lower I set vtec the more midrange power I made. However, the lower I set vtec the more I lost up top. There was that power dip at 5000 rpms that, no matter what the settings were, the lines wouldn't budge.
I can pretty much say I'm disappointed at the final numbers. I thought after those baselines that 210whp would be easily within reach.
Modified by DarkKnight1 at 1:48 PM 6/28/2005
Old May 21, 2005 | 12:25 PM
ShaunRR's Avatar
HT White Ops
Community Builder
Default Re: Rocket Motorsports KTeller Spec'd H22 H22a Cams and Valvetrain Dyno (DarkKnight1)
Old May 21, 2005 | 01:22 PM
G U E C O's Avatar
Default Re: Rocket Motorsports KTeller Spec'd H22 H22a Cams and Valvetrain Dyno (rochesterricer)
waiting for the results
Old May 21, 2005 | 01:27 PM
Humble Performance's Avatar
Default Re: Rocket Motorsports KTeller Spec'd H22 H22a Cams and Valvetrain Dyno (stock93cx)
Keep us updated !
Old May 21, 2005 | 01:46 PM
GOLDBERG's Avatar
Default Re: Rocket Motorsports KTeller Spec'd H22 H22a Cams and Valvetrain Dyno (8secEg)
well all this is is a teaser also make a post when YOU actually have a dyno to post up..if someone else had it im sure they wouldve posted it
Old May 21, 2005 | 05:57 PM
Adam.'s Avatar
Default Re: Rocket Motorsports KTeller Spec'd H22 H22a Cams and Valvetrain Dyno (GOLDBERG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GOLDBERG &raquo;</TD></TR><TR><TD CLASS="quote">well all this is is a teaser also make a post when YOU actually have a dyno to post up..if someone else had it im sure they wouldve posted it</TD></TR></TABLE>
lol sorry, it was also kind of a call out to see if anyone else had them. I know kteller has sold at least 10 sets now and someone has had to have had them dyno tuned.
Old May 21, 2005 | 06:00 PM
Innovation's Avatar
Ill be the first to recieve new H sereies cores from Rocket
Old May 21, 2005 | 06:07 PM
Adam.'s Avatar
Default Re: Rocket Motorsports KTeller Spec'd H22 H22a Cams and Valvetrain Dyno (Innovation)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Innovation &raquo;</TD></TR><TR><TD CLASS="quote">Ill be the first to recieve new H sereies cores from Rocket </TD></TR></TABLE>
So then you are getting the KTeller regrind specs, but from new cores?
Old May 21, 2005 | 06:09 PM
Innovation's Avatar
New cores, no specs that are available now...
Im gonna work with Rocket on the new H series stuff
Im sure when theyre done Mike will have those for sale too, Mike "AKA" Kteller is one of the best when it comes to customer service and is always keeping a close eye on the markets new offerings. If his customers want it, he gets it, no matter what it is or how many hoops of fire he has to jump through to get it
Old May 21, 2005 | 06:44 PM
ShaunRR's Avatar
HT White Ops
Community Builder
Gotta wait for the new cores to come out though. I hope its not too long. I've had a lot of serious inquiries about H series cams.
Old May 22, 2005 | 01:50 AM
@ries's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stock93cx &raquo;</TD></TR><TR><TD CLASS="quote">waiting for the results </TD></TR></TABLE>
ditto
Old May 22, 2005 | 11:25 AM
machine4321's Avatar
you bastard
i cant wait to get some money ...
you HAVE to make sure you keep us updated ..please
Old May 22, 2005 | 11:48 AM
Innovation's Avatar
Default Re: Rocket Motorsports KTeller Spec'd H22 H22a Cams and Valvetrain Dyno (machine4321)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by machine4321 &raquo;</TD></TR><TR><TD CLASS="quote">you HAVE to make sure you keep us updated ..please </TD></TR></TABLE>
They will be featured in a project article fairly soon
Old May 25, 2005 | 10:00 AM
KTeller8's Avatar
They will be featured in a project article fairly soon</TD></TR></TABLE>
Yes believe me good things! good things are coming!
Old May 27, 2005 | 04:30 AM
Adam.'s Avatar
Default Re: Rocket Motorsports KTeller Spec'd H22 H22a Cams and Valvetrain Dyno (KTeller8)
Just as an FYI, I'm going to the dynojet on Sunday to get some baseline numbers for comparison. Blah blah blah, yes I know, hard to compare dynos not on the same day. Well it's the best I could do, just be happy that I plan on coming back to the same dyno afterwards to do a comparison run, no matter where I do my actually tuning.
Old May 27, 2005 | 07:06 PM
h22slohatch's Avatar
let us know how the cams dyno,im very interested in the h22 rocket cam regrinds,they sure did look good against the type-s cams
Old May 29, 2005 | 07:58 PM
Adam.'s Avatar
Default Re: Rocket Motorsports KTeller Spec'd H22 H22a Cams and Valvetrain Dyno (h22slohatch)
bump for the updated baseline on my motor. Cam install should be within two weeks and dyno tuning about four. Sorry got pushed back a little.
Modified by DarkKnight1 at 10:36 AM 5/30/2005
Old May 29, 2005 | 10:14 PM
high_revs's Avatar
want to see the results
Old May 30, 2005 | 06:38 AM
. o 69 o .'s Avatar
Default Re: (all mOtor h23)
im also deciding if i should buy these. I am pulled between keeping my h22 civic and modding it or selling my civic and buying a new one so i can do the H2B and a built motor.
One thing is for damn sure, H22 motors need cams
bump for scooping a set of these cams.
Old May 30, 2005 | 09:02 AM
Adam.'s Avatar
Default Re: (B16B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16B &raquo;</TD></TR><TR><TD CLASS="quote">im also deciding if i should buy these. I am pulled between keeping my h22 civic and modding it or selling my civic and buying a new one so i can do the H2B and a built motor.
bump for scooping a set of these cams.</TD></TR></TABLE>
If you look at the baseline of my motor with the 10.6 compression it's quite obvious that these motor are held back by their need to breath. Large intake runners, a good header, and 2.5" exhaust, followed up with tuning will net great gains on the h22a. 2.2 Liters is a force to be reckoned with against even fully built lsvtecs and b20vtecs.
Old May 30, 2005 | 10:07 AM
. o 69 o .'s Avatar
Default Re: (DarkKnight1)
i agree, and add this. once you've gone h22, you can never enjoy a B-series again.
I want to build an H22 (top & bottom) and use the Townsend Bros adaptor kit and mount an ITR tranny to it. OEM axles, Hasport DCSTK mounts, and b-series shift linkages = a killer setup... See ya later b20/vtec's
Old May 30, 2005 | 10:22 AM
Adam.'s Avatar
Default Re: (B16B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16B &raquo;</TD></TR><TR><TD CLASS="quote">i agree, and add this. once you've gone h22, you can never enjoy a B-series again.
I want to build an H22 (top & bottom) and use the Townsend Bros adaptor kit and mount an ITR tranny to it. OEM axles, Hasport DCSTK mounts, and b-series shift linkages = a killer setup... See ya later b20/vtec's</TD></TR></TABLE>
Well, I actually am thinking along the lines of a higher final drive ratio. Unfortunately for the h-series they are few and far between and very expensive. It was a long time ago, but I think there is one from Saenz for about $6,000.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkKnight1 &raquo;</TD></TR><TR><TD CLASS="quote">
If you look at the baseline of my motor with the 10.6 compression it's quite obvious that these motor are held back by their need to breath. Large intake runners, a good header, and 2.5" exhaust, followed up with tuning will net great gains on the h22a. 2.2 Liters is a force to be reckoned with against even fully built lsvtecs and b20vtecs.</TD></TR></TABLE>
ive been a firm beliver in that for years...its frustrating when the b series got all the good parts ..i mean for a while it was hard to find a 200+whp h22 even with cams
soon as the header rush started thes plenty of 195+whp h22 on stock internal's and bolt ons ..
cant wait to see the results
i finally rented my basement out so i told the wife it goes to the car fund haha id love to pick a set up
Old May 30, 2005 | 10:29 AM
Adam.'s Avatar
Default Re: (machine4321)
i finally rented my basement out so i told the wife it goes to the car fund haha id love to pick a set up </TD></TR></TABLE>
The thing is, you can't beat the price @ $480 w/ cores or $530 without. And that's full valvetrain, cams/springs/retainers.
Old May 30, 2005 | 11:28 AM
. o 69 o .'s Avatar
you're damn skippy!! ... and Rocket was telling me that if i send my JDM cams, he can make them a bit more agressive then the USDM ones. P I M P !
Hey Machine, you still selling that Single row crank pulley? I"m stil interested in it if you are
