What would happen if you ran a p2t computer on a 98 civic???
Old May 21, 2005 | 09:47 AM
No's Avatar
No
Default What would happen if you ran a p2t computer on a 98 civic???
Just wondering because thats what i got...jdm b16 obd1 swap in a 98 civic dx.Im running a p2t computer and i cant get the obd port too read.The car does run...but runs horrible.Anyone know if i switched too the appropriate ecu it would be ok?
Old May 21, 2005 | 12:02 PM
Honduh Tooner's Avatar
Default Re: What would happen if you ran a p2t computer on a 98 civic??? (narib2oo1)
thats weird, should work fine, had that in my buddys car except it was a b20vtec in a 97. no cel? what r the symptoms u have?
Old May 21, 2005 | 03:51 PM
hondadriver's Avatar
Default Re: What would happen if you ran a p2t computer on a 98 civic??? (Honduh Tooner)
Yeah i'm running that ecu also in my 98 lx with a JDM 2nd gen B16a. But i got th p1457 code. Still after 2 years and 3 days left at honda stil can't be figured out.
Hey Honduh Tooner. What model civic did you guys put the p2t in. LX, EX, etc???
Old May 21, 2005 | 06:22 PM
Default Re: What would happen if you ran a p2t computer on a 98 civic??? (hondadriver)
it was a dx coupe with the b20vtec and a civic ex engine harness
Old May 22, 2005 | 08:18 AM
Did you have to add anything, in the emission system wise. becasue All my **** is hooked up, but I saw in the helms book that the 99-00 civics have a purge joint between the charcoal canister and the purge control solenoid. And i'm wondering if not having that is causing my p1457 code. Thanks for the info!
Davenflorida
Dec 9, 2012 12:29 PM
hobo79
Aug 15, 2001 02:54 PM
