d16a6 with a ported d15b2 head
Okay, I want to port and polish the head on my d16a6, BUT I don't want downtime. I have 3 d15b2 heads laying around. Are the heads the same, but just a different cam? If I have the d15b2 head ported and polished, then install the d16a6 cam, will that be the same as if I got the d16a6 head ported and polished?
I've heard the d16a6 head is better flowing, BUT after you port and polish it, shouldn't it be equal, or not?
I have a friend that ported his head on his b16. Should I just have him polish the head, or should I have him port it as well? I've heard if you're not a professional you can **** up the head and lose hp.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blah13 »</TD></TR><TR><TD CLASS="quote">Same casting, same head, different cam, thats bout it.
Yup.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Killa-X »</TD></TR><TR><TD CLASS="quote">I have a friend that ported his head on his b16. Should I just have him polish the head, or should I have him port it as well? I've heard if you're not a professional you can **** up the head and lose hp.</TD></TR></TABLE>
You are correct, if you don't know what you are doing, for your application, you can lose hp and torque. Also, B series heads are different that D, so he can possibly run into the water jackets and you will be up crap creek.
</TD></TR></TABLE>Yup.
just gasket match it and port match it so every thing flows smooth and have him polish every thing and leave the intake side a little rough and make the exhaust side smooth. i think there was a write up somewhere on this website about porting and polishing. you would probably see a slight gain but nothing insane. its always good to have smooth flow though. and what do you plan on using this head for? i.e. boost or n/a/?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted_hatch_216 »</TD></TR><TR><TD CLASS="quote">just gasket match it and port match it so every thing flows smooth and have him polish every thing and leave the intake side a little rough and make the exhaust side smooth. i</TD></TR></TABLE>
Agreed, dremels are your friend.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KILLA-X »</TD></TR><TR><TD CLASS="quote">hmmm, would you actually see any gains from polishing the head and intake manifold? Or would it be unnoticable increase?</TD></TR></TABLE>
You'll see gains, but it wont register on the butt-dyno. Course this also depends on what else has been done to the motor...a stock motor might see 3hp max with a polish...throw some cams and rev it higher maybe 5ish. But for another hours work it will flow better which will be a few hp and maybe a .1mpg increase.
bigsnorlax
May 7, 2009 11:08 AM
kyle h.
10
Mar 30, 2003 01:23 PM
