Cuttin springs?
Old May 20, 2005 | 07:49 PM
BigDawwg6969's Avatar
Default Cuttin springs?
Anyone ever done this to a 91 hatch? was lookin for a cheaper way to lower my car and heard about cuttin the springs.... thanks!
Old May 20, 2005 | 07:59 PM
darkstarmeyers's Avatar
yea dont do it...ive heard that its bad to do
Old May 20, 2005 | 08:19 PM
kaoss_11's Avatar
B A N N E D
It will ride like straight ****
Old May 20, 2005 | 08:20 PM
Setsuna F Seiei's Avatar
Honda-Tech Platinum Member
Default Re: (darkstarmeyers)
The problem with cutting the springs is that you have no clue what sort of spring rates you would have after you do it. Don't do it
Old May 20, 2005 | 08:32 PM
HamiltonRex's Avatar
Default Re: (BrokeAssPinoy)
just heat up the springs with a torch
Old May 20, 2005 | 08:44 PM
99teggsr's Avatar
Default Re: (HamiltonRex)
Dont do it. thats what stunnas with cadalacs and lincolns do. This guy i work with cut his springs on his lincoln and its so low that his rear bumper nearly got ripped off and its now held on by bungee cords.
Old May 21, 2005 | 01:40 AM
93formula's Avatar
Default Re: (99teggsr)
people still cut sprigns??? just save up and get a good set of springs youll thank your self later. not worht the quickie lowering job. youll mess up a lot of your suspension parts and it will cost more in the long run.
Old May 21, 2005 | 01:42 AM
l e o h j's Avatar
do it if you like bouncing up and down while running on the freeway...
Old May 21, 2005 | 02:51 AM
92integra_gs's Avatar
Default Re: (93formula)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93formula &raquo;</TD></TR><TR><TD CLASS="quote">people still cut sprigns??? just save up and get a good set of springs youll thank your self later. not worht the quickie lowering job. youll mess up a lot of your suspension parts and it will cost more in the long run.
yup...well said
Old May 21, 2005 | 07:57 AM
Stoich's Avatar
Default Re: (92integra_gs)
8o bucks on ebay for some springs
Old May 21, 2005 | 04:46 PM
Abram AH5's Avatar
Default Re: Cuttin springs? (BigDawwg6969)
bah its not that bad if u just go 1 1/2 coils or so
if you going to be carrying stuff in the back or people and have hils and bumps to go over you have the chance of bottoming out
if your cheap or its a short term thing till you save for beter springs go for it
Old May 21, 2005 | 04:54 PM
The Phil's Avatar
Default Re: Cuttin springs? (Hoopty Honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hoopty Honda &raquo;</TD></TR><TR><TD CLASS="quote">bah its not that bad if u just go 1 1/2 coils or so
if your cheap or its a short term thing till you save for beter springs go for it </TD></TR></TABLE>
No, wrong.
Old May 21, 2005 | 04:57 PM
Abram AH5's Avatar
Default Re: Cuttin springs? (xthephilx)
your wrong
I did it with no problems and i have a nasty dirt drive way to go up
Old May 21, 2005 | 05:49 PM
Hamstr323's Avatar
http://www.swapshopracing.com $65.00 coilovers
alex14
31
Jan 30, 2011 11:03 AM
Paluce
Suspension & Brakes
Dec 8, 2008 08:59 AM
BlueRex1020
Feb 9, 2007 04:43 PM
Thanks knightsport!
Dec 1, 2005 04:46 PM
