b16DA9 sputering after spark plug install???HELPP
Old May 20, 2005 | 06:09 PM
D-meet07's Avatar
Default b16DA9 sputering after spark plug install???HELPP
Story. I just bought a 91 integra with a jdm b16(pr3). Drove it and noticed that it dies down or pauses if i keep the rpm steady. When i press the gas it seems to drive fine. So I figured that i would change the plug. When I pulled the plugs out i noticed that all except plug 1 had oil on it. Now this car also has an oil leak around the head gasket on the passenger side. After putting in the Iridium denso plugs in, the car sputter and seems like it was about to cut off. When i got home i checked the plugs to see if they where drowned in oil again, but there where fine. What could the problem be. I took the car back out 30 minutes later and it seem fine. It sputtered once or twice but that was it.
can someone help PLEASEE???
Old May 21, 2005 | 10:03 AM
JDAMC's Avatar
Default Re: b16DA9 sputering after spark plug install???HELPP (turbo90lude)
Take it and get a leak down test.
Old May 21, 2005 | 10:33 AM
HoUTX98GSR's Avatar
Default Re: b16DA9 sputering after spark plug install???HELPP (JDAMC)
yeah leakdown fo sho.
with oil on the plugs it sounds like bad news. did you gap the plugs properly?
Old May 21, 2005 | 12:18 PM
D-meet07's Avatar
Default Re: b16DA9 sputering after spark plug install???HELPP (HoUTX98GSR)
nah. it drives fine now. I think it will hold up for a few months. I have a ls engine at my freinds. Im about to be ls/vtec.
thanx guys
oakpwr
Apr 28, 2009 10:47 AM
InvaderJim
Mar 8, 2009 05:42 PM
Midori Green
15
May 25, 2007 12:39 PM
Stryker908
Nov 11, 2002 02:52 AM
Doogie Howser
May 22, 2002 11:59 AM
