b18 in 91 civic... has spark and fuel = no start
Old May 20, 2005 | 05:29 PM
gambo117's Avatar
Default b18 in 91 civic... has spark and fuel = no start
car is gettin fuel to rail..injectors seem to be clicking (ie working) all plugs getting spark= will not start
b18b1 into a 91 civic DX
OBD0 pr4 ecu, distributor, injectors, civic wiring harness, resistor box, alternator
cam timing dead on
new plugs
new wires
checked 2 different distributors
verified ALL changes in wiring for dpfi to mpfi and added cylinder sensor to ecu from distributor
checked all fuses
checked all grounds
replaced with known good ECU
fuel pump cycles on ignition switch
all plugs give spark
getting fuel to rail
injectors are recieving signal (slight click/vibration check)
car cranks
has gas in tank
no codes in ecu
ecu led flashes with ignition on/off
battery new
ALL connections checked/rechecked for continuity!!!!!!!!! ALL soldered!!!
searched everywhere for a clue
SOMEONE PLEASE HELP!!!!
$100 REWARD to any info leading to the resolution of this problem!!!!!
Jim
Modified by gambo117 at 9:55 PM 5/20/2005
Old May 21, 2005 | 10:15 AM
gambo117's Avatar
Default Re: b18 in 91 civic... has spark and fuel = no start (gambo117)
no one wants 100 bux???
Jim
Old Aug 6, 2005 | 03:06 PM
roxy2000's Avatar
Did you get it running? I'm having similar issues and am at the end of my rope...
Old Aug 6, 2005 | 03:09 PM
kulangot's Avatar
Default Re: b18 in 91 civic... has spark and fuel = no start (roxy2000)
timing???
Old Aug 6, 2005 | 03:16 PM
integ u's Avatar
I had the same problems in my hatch and i got pissed and just took it to TSR in glen burnie.
Ask for Mike. He said I pulled some injectors wires out, going from the ECU.
Old Aug 6, 2005 | 03:40 PM
Magick211's Avatar
Default Re: b18 in 91 civic... has spark and fuel = no start (integ u)
Does it ever attempt to start at all?
Twisted sid
Mar 27, 2017 12:47 PM
91civicwa
Nov 5, 2012 10:07 AM
mlb4046
Jan 23, 2011 03:53 PM
spnej1
77
Feb 2, 2010 12:03 AM
Lsos
Mar 4, 2005 11:49 AM
