Need some help on keyless door handles?
Old May 20, 2005 | 04:23 PM
ivanson's Avatar
Default Need some help on keyless door handles?
Im about to buy some keyless door handles but im not sure if
i need something to open and lock it. I know you need to have an alarm
remote to open/lock it, but im not sure if i need anything else.
Plz i need some help and/or suggestions. thanks
Old May 20, 2005 | 04:44 PM
xci_ed6's Avatar
Default Re: Need some help on keyless door handles? (ivanson)
You need to have keyless entry, so some lock actuators,. That is all.
Old May 20, 2005 | 05:19 PM
ivanson's Avatar
do you need to have like those power door locks for this?
If so, can i get some from a newer model civic and customize
fit it on my crx. reply back thanks
Old May 20, 2005 | 05:42 PM
spongerlbc's Avatar
Just install them and make sure to lock the door before you finish everything up and shut the door. Climb in through your trunk its the jdm way yo.
Old May 20, 2005 | 07:51 PM
ivanson's Avatar
Default Re: (spongerlbc)
so how the hell will i be able to open it?
AHAHAHA
Old May 20, 2005 | 08:46 PM
Louie B.'s Avatar
Default Re: (ivanson)
Your local stereo shop should be happy to sell you some universal door lock accuators which will be much easier to install than some old factory accuator that wasn't origionally meant for the car. They usually go for arround $15-20 ea. Install the accuators and wire them to the door lock output of an alarm or keyless entry module. Relays may be required depending on manufacturer of the alarm/keyless. Again, your local stereo shop should have the knowlege and expertise to help you out with this.
After you get it done, make sure you always have a key handy that opens the rear hatch and never shave that lock!!! If you leave your lights on or something dumb like that, the keyless entry will not work once the car battery is dead so you'll have to crawl through the rear to unlock the doors from the inside.
Old May 20, 2005 | 09:03 PM
ivanson's Avatar
Default Re: (Louie B.)
my key doesnt open my hatch. i think its from a different
car. you think can make a key for that or change the chambers.
Old May 21, 2005 | 06:36 AM
Louie B.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ivanson &raquo;</TD></TR><TR><TD CLASS="quote">my key doesnt open my hatch. i think its from a different
car. you think can make a key for that or change the chambers.</TD></TR></TABLE>
pull the key cylinder from the car and take it along with your ignition key to any locksmith and they can change the lock to work with the same key as the ignition.
Old May 21, 2005 | 01:18 PM
ivanson's Avatar
k thanks man.
Karado58
Nov 24, 2009 08:47 PM
silverejhatch
Dec 29, 2004 05:29 PM
boomnn
Nov 29, 2004 10:30 AM
htownteg
Mar 22, 2003 02:10 PM
creasian
Dec 20, 2002 01:20 PM
