After timing belt change, V-tec sound change
Old May 20, 2005 | 03:54 PM
951dc5's Avatar
Default After timing belt change, V-tec sound change
after changing the water pump and timing belt, i notice the vtec sound a little quite than usual. Before vtec usually pull right at 5,000 rpm and it would pull hard enough to snap my head back. Now it'll kicks @ 5,200 rpm with a low vtec shriek. I did align it tdc with the cam gears and pulley mark. Or did it has to be perfect? any ideas would be helpful. cuz i dont want to run it abnormal.. thanks
Old May 20, 2005 | 04:04 PM
Duster's Avatar
Default Re: After timing belt change, V-tec sound change (Prelude951)
If you didn't line up TDC you would defently know about it, the car would sound like crap and you could possibly hear your pistons hitting your valves. So its not that...other than that i can't help ya with the vtec late engage though.
Old May 20, 2005 | 04:15 PM
951dc5's Avatar
Default Re: After timing belt change, V-tec sound change (NotherHonda)
i did line it as close as i can. but the thing is that there is no pointer on the cover to line it with the pulley mark. I line it on the pointer of the flywheel but putting the belt back on cause it to slightly move. So when u guys line up the cams gears..do u guys line it up straight as it looks straight to you then put on the belt?
Old May 21, 2005 | 04:44 PM
precord96's Avatar
Sounds like you need to redo it. You're probably off somewhere, I had a bolt drop into the timing belt before and made the crank skip a tooth. Couldn't figure out why my car was pulling so slow in vtec, until I pulled everything apart to change the oil pump and found the crank was off from the cams, being retarded a tooth on the timing belt.
Old May 22, 2005 | 07:44 PM
951dc5's Avatar
Default Re: After timing belt change, V-tec sound change (precord96)
so if skipped only a tooth, would it run like a bit*h where you can notice..for sample.. it would idle like a bit*h. becuz it still idle okay and it runs a little different, cant really tell it gain power or lose power but only thing changes is vtec sound.
Old May 22, 2005 | 09:36 PM
precord96's Avatar
That's how mine was. My car idled fine, maybe a few rpm's higher. I couldn't really notice with normal driving, but under full throttle the car lagged as soon as it went into vtec and kept lagging until redline.
Old May 23, 2005 | 11:05 AM
951dc5's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by precord96 &raquo;</TD></TR><TR><TD CLASS="quote">That's how mine was. My car idled fine, maybe a few rpm's higher. I couldn't really notice with normal driving, but under full throttle the car lagged as soon as it went into vtec and kept lagging until redline.</TD></TR></TABLE>
so did you get that fixed. did you had line it all back again?
Old May 23, 2005 | 04:40 PM
precord96's Avatar
Yeah I fixed everything putting the oil pump back in, and it's fine now.
Old May 23, 2005 | 04:48 PM
951dc5's Avatar
perhaps..did you line the mark on the oil pump pulley to groove on the block mark? i couldnt get a good angle view to align it so i line it as straight as it looks. was wondering if that can cause such problem..
Kiojoe
Honda CR-V & Element
Mar 11, 2014 04:20 AM
SPEED FoRCE
Jan 14, 2010 05:06 AM
erok515
Jul 29, 2008 04:22 AM
pootie.teng
Jan 30, 2004 06:58 PM
made in JAPAN
Oct 26, 2003 08:09 PM
