compresstion test results-180
Old May 20, 2005 | 02:51 PM
BLUE EH3's Avatar
Help we my pennies
Default compresstion test results-180
i did my compresstion test yestersday and got 180 on all 4.. is 180 good?
Old May 20, 2005 | 03:10 PM
BLUE EH3's Avatar
Help we my pennies
Default Re: compresstion test results-180 (BLUE EH3)
whats the diff, between a leakdown ansd compression test?
Old May 20, 2005 | 03:21 PM
BLUE EH3's Avatar
Help we my pennies
bump
Old May 20, 2005 | 05:26 PM
BLUE EH3's Avatar
Help we my pennies
k
Old May 20, 2005 | 05:53 PM
BLUE EH3's Avatar
Help we my pennies
whats the math behind 180 or 250psi?
Old May 20, 2005 | 05:59 PM
BLUE EH3's Avatar
Help we my pennies
compression ratio vs compresion???
Old May 20, 2005 | 06:23 PM
mmuller's Avatar
Mad Scientist
well, compression test dont really tell you all that much.since altitude, temp, comp. tester are all variables and will yield different readings.
What compression are you running?
whats important is to look for the #'s to be even.
Leak down test is the best way.
pretty basic explanation; you inject air in the compustion chamber with the piston at TDC; the gauge will tell you how much of that air is leaking out.
then you hear or see where it comes from.
exhaust, intake, valve cover breather, radiator
Old May 21, 2005 | 07:57 AM
BLUE EH3's Avatar
Help we my pennies
Default Re: compresstion test results-180 (mmuller)
b20
Old May 22, 2005 | 08:38 AM
BLUE EH3's Avatar
Help we my pennies
bump
Old May 23, 2005 | 09:48 PM
blackeg's Avatar
b20b or b20z? 180 is like perfect on point for the b20b, and since the static compressionn on the b20z is a little more, then 180 would be a tad bit low. remember that consistancy is just as important as the # itself
Old Nov 13, 2005 | 07:04 AM
BLUE EH3's Avatar
Help we my pennies
Default Re: compresstion test results-180 (blackeg)
B20B
humboldt_skim
May 31, 2008 08:18 AM
godnf8
Feb 12, 2007 07:33 AM
Got_soy
28
Aug 8, 2005 12:49 PM
93H22ACX
Jul 15, 2004 02:33 AM
Jordan_4WS
Apr 23, 2002 02:58 PM
