B16a2 Swap in my 95 EG
Old May 20, 2005 | 02:46 PM
Eq_Coupe2k's Avatar
Default B16a2 Swap in my 95 EG
Hello Aqain People thanks for the help youve qiven me since i Joined H.Tech. I have a B16a2 Full block. I need a Head,Tranny and ECU. If theres anythinq else i need. Let me know. and If any of you are sellinq anythinq i need to complete this swap also let me know.. Your Fellow Member.
Eq_Coupe2k
Old May 20, 2005 | 02:51 PM
HATCHingMN's Avatar
Default Re: B16a2 Swap in my 95 EG (Eq_Coupe2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eq_Coupe2k &raquo;</TD></TR><TR><TD CLASS="quote">Hello Aqain People thanks for the help youve qiven me since i Joined H.Tech. I have a B16a2 Full block. I need a Head,Tranny and ECU. If theres anythinq else i need. Let me know. and If any of you are sellinq anythinq i need to complete this swap also let me know.. Your Fellow Member.
Eq_Coupe2k </TD></TR></TABLE>
you'll need....
- integra motor mounts
- b-series shift linkage
- throttle cable from delsol VTEC (DOHC)
- b-series axles
Old May 20, 2005 | 04:55 PM
hondaracing1's Avatar
Default Re: B16a2 Swap in my 95 EG (HATCHingMN)
sorry for the hijack but for him to put the integra mounts on what mounts does he use for the tranny?
Old May 20, 2005 | 05:45 PM
Status Sean's Avatar
Default Re: B16a2 Swap in my 95 EG (hondaracing1)
the integra tranny mount works fine !
Old May 20, 2005 | 06:03 PM
Eq_Coupe2k's Avatar
Default Re: B16a2 Swap in my 95 EG (Senses Fail y0!)
Will this ECU work on My b16a2 (JDM 88-91 Honda B16A Vtec Ecu PW0)??
Old May 20, 2005 | 06:09 PM
germz's Avatar
you gonna need a obd1 ecu (p28/p72/p30)
Old May 20, 2005 | 06:32 PM
Eq_Coupe2k's Avatar
Default Re: B16a2 Swap in my 95 EG (germz)
JDM P30 5-Speed ECU B16A Honda Civic EG 99 SiR, Will this one work?
Old May 20, 2005 | 07:29 PM
JohnnyWash1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eq_Coupe2k &raquo;</TD></TR><TR><TD CLASS="quote">JDM P30 5-Speed ECU B16A Honda Civic EG 99 SiR, Will this one work?
Isn't that one OBD2? You need pr3 (make sure it is obd1), p72, or p28.
Old May 20, 2005 | 08:19 PM
neophyte210's Avatar
Default Re: B16a2 Swap in my 95 EG (JohnnyWash1)
sry about jackin tread!!! hatchingMN i have a b18c1 head on a b16a2 bottom end and when vtec hits my car kind shakes.... does that mean i need new motor mounts???
also i have a p28 ecu that i might want to get rid of seein how i need a p72 for the gsr head
Old May 20, 2005 | 08:45 PM
germz's Avatar
Default Re: B16a2 Swap in my 95 EG (neophyte210)
just check if the mounts are ripped....
Old May 20, 2005 | 08:56 PM
how can i tell if the mounts are ripped or not.... if its not the mounts then what would make the car shake???
Old May 21, 2005 | 01:39 AM
Timmay's Avatar
well guessing you have a 00 civic?????
for 96-00 you need
99-00 SI rear "L" bracket
99-00 SI a/c mount
99-00 SI tranny torque mount( i think teg mount works also)
stock sohc top tranny mount and engine mount work
a p2t 99-00 SI ecu or obd2b-obd1 harness and a chipped p28 or stock p30
if the car is a 92-95 you need
94-00 Integra "L" bracket
94-00 teg a/c mount
94-00 teg tranny torque mount
Old May 21, 2005 | 05:10 AM
CRXified's Avatar
Default Re: B16a2 Swap in my 95 EG (Timmay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmay &raquo;</TD></TR><TR><TD CLASS="quote">well guessing you have a 00 civic?????
for 96-00 you need
99-00 SI a/c mount
94-00 teg a/c mount
the post title says he has a 95 EG. when i swapped in my JDM B16 a month or so ago i use all stock mounts from my d15 EXCEPT i needed the rear "L" bracket. all the other mounts mined up right. u will need the B16 A/C BRACKET that bolts onto ur stock torque mount, but the tranny mount will mount up. when i bought my swap it came with all the brackets i needed.
but as said above u will need a p30 or chipped p28. also a few little things like a lower rad hose from a 90-93 teg and u can shimmy ur old lower rad hose and cut it to fit for the top one. this required me to heat it up a bit to slide it on the motor side because its a tad bit smaller in diameter.
hope this helped
b16_coupe
Jul 9, 2012 06:49 AM
Carnivorous19
Jul 14, 2011 02:24 PM
90ed6
Aug 7, 2008 09:09 AM
twentytwocpb
Jan 14, 2008 09:35 AM
scrcrw
Feb 15, 2007 04:16 PM
