lsvtec 15,000 after build noticed oil pan bolts/nuts loose
Old May 20, 2005 | 02:41 PM
lsvtec101's Avatar
Default lsvtec 15,000 after build noticed oil pan bolts/nuts loose
was putting my toda header on today and noticed two bolts and one nut fell off the oil pan and almost all the others are loose. am i missing something on my setup that i should need? what could be causing this?
Old May 20, 2005 | 04:30 PM
Sam92Teg's Avatar
Default Re: lsvtec 15,000 after build noticed oil pan bolts/nuts loose (lsvtec101)
Did someone forget to torque them to 9 ft/lbs?
Old May 20, 2005 | 04:42 PM
BolivianDc2's Avatar
Default Re: lsvtec 15,000 after build noticed oil pan bolts/nuts loose (Sam92Teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam92Teg &raquo;</TD></TR><TR><TD CLASS="quote">Did someone forget to torque them to 9 ft/lbs?</TD></TR></TABLE>
thats my guess. Same thing happend to me when I went too ***** arm installing my oil pan, no oil was leaking so I just put some new bolts on
Old May 20, 2005 | 05:21 PM
Race Egr's Avatar
Default Re: lsvtec 15,000 after build noticed oil pan bolts/nuts loose (BolivianDc2)
Ive seen this to even on virgin motors where the oil pan was never removed i guess the just vibrate loose over time becasue 9lb's of torque is nothing ,but i dunno
Fred Dukes
Apr 29, 2017 02:48 PM
TOO MUCH TORQUE
Jan 7, 2011 06:46 PM
DjTrex
Sep 24, 2005 01:40 PM
OneFire
Jul 11, 2005 10:32 PM
internet ay
Jul 31, 2002 11:46 AM
