TDC d16
Old May 20, 2005 | 10:14 AM
kabaroo's Avatar
Default TDC d16
im trying to find TDC on my d16z6 head.
there are some arrows (3) and the word "up" im assuming that the word up should be pointed straight up at TDC. I have done that. I have but one problem. the #4 valves seem to be open just a little bit, i mean all 4 valves are open. Just a little bit tho.
My Head and short block are separated. I thought it would be easier to put them at TDC before bolting them together.
The #1 and #4 pistons are all the way up.
Also i am refering to #1 cylinder and the one on the cam gear side and #4 on the dizzy side.
Old May 20, 2005 | 10:16 AM
kabaroo's Avatar
Default Re: TDC d16 (kabaroo)
its a built head by JG and a built block w/ SRP pistons too if that matters.
Old May 20, 2005 | 10:26 AM
JDMisGOOD's Avatar
Since i'm not there to help you buddy... here is some pictures for you!
Old May 20, 2005 | 10:28 AM
JDMisGOOD's Avatar
Default Re: TDC d16 (JDMisGOOD)
all 4 valves on cylinder number 4 are open? hows number 1 look?
Old May 20, 2005 | 10:32 AM
Ignitecivic's Avatar
i forgot how the valves are open but as long as ur cam gear is set like the pic above, ur good
Old May 20, 2005 | 10:36 AM
kabaroo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMisGOOD &raquo;</TD></TR><TR><TD CLASS="quote">all 4 valves on cylinder number 4 are open? hows number 1 look?</TD></TR></TABLE>
#1 they are all closed. And the cam gear looks like the pic above.
As for the crank, done you just want the #1,4 pistons ALL the way up? I dont have the timing belt cover on as of now. ill put it on and check.
Im just wondering why all 4 valves are slightly open, could something be wrong? btw this is a fresh head, 0 miles.
Old May 20, 2005 | 10:37 AM
EJ1 wilcox's Avatar
Default Re: TDC d16 (Ignitecivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ignitecivic &raquo;</TD></TR><TR><TD CLASS="quote">i forgot how the valves are open but as long as ur cam gear is set like the pic above, ur good </TD></TR></TABLE>
Yup... position the cam gear like the picture and you should be fine.
Old May 20, 2005 | 10:38 AM
kabaroo's Avatar
Default Re: TDC d16 (EJ1 wilcox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox &raquo;</TD></TR><TR><TD CLASS="quote">Yup... position the cam gear like the picture and you should be fine.</TD></TR></TABLE>
cool, thanks.
One last Question. Are all D series cams such a pain to turn? i cannot turn it by hand.
Old May 20, 2005 | 10:54 AM
JDMisGOOD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kabaroo &raquo;</TD></TR><TR><TD CLASS="quote">
cool, thanks.
One last Question. Are all D series cams such a pain to turn? i cannot turn it by hand.</TD></TR></TABLE>
think that little cam has to open all 16 of the valves by it self... you need to get it a friend!
Old May 20, 2005 | 12:02 PM
kabaroo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMisGOOD &raquo;</TD></TR><TR><TD CLASS="quote">think that little cam has to open all 16 of the valves by it self... you need to get it a friend! </TD></TR></TABLE>
But i have no friends... Its not that hard to turn anymore. With my old timing belt wrapped around the gear and a pry bar i can move it.
I didnt even realize that was you giving my advise till now!
thanks jordan
Old May 20, 2005 | 12:06 PM
JDMisGOOD's Avatar
lol i was saying your cam needs a friend... literally put...get a DOHC! Hopefully this week we shall see what kind of numbers joeys car puts down... as long as his clutch hangs on...
Old May 20, 2005 | 12:23 PM
kabaroo's Avatar
yea, he stopped by today and he thought the clutch might be dying.
I see what you mean by "get it a friend". Thats not gunna happen, this year at least.
Old May 20, 2005 | 01:12 PM
Morning Call's Avatar
u can use a screw driver
stick it in the holes in the cam gear and u should be able to use a lip on the engine as leverage
thats what i had to do after i stripped the **** out of my cam bolt.. btw anyone got any ideas how to replace that cam bolt? i was thinking best way would likely be to weld a socket onto it.. or just drill out a peice of metal, slip it over the bolt head, and weld it then crank it...
when i say stripped i mean its stripped.. pretty much round..
Old May 20, 2005 | 02:54 PM
kabaroo's Avatar
Default Re: (Morning Call)
you could use a grinder of some sort to grind a slit in the bolt so you could use a big flathead screw driver, but then you wouldnt get much leverage on the bolt....
weld a socket on!
MMMGIRL
Engine Machining & Assembly
Oct 19, 2016 08:48 PM
carlosd68
16
Mar 21, 2013 11:04 PM
HondaKing90
Engine Management and Tuning
Feb 13, 2010 09:09 AM
CRXREFIC
Nov 29, 2009 08:59 PM
Layziebtnh055
May 15, 2004 09:51 AM
