A/C Connectors? can i cut them?
Old May 20, 2005 | 10:07 AM
scul8r1990's Avatar
Default A/C Connectors? can i cut them? (img)
Removed the A/C compressor and bracket from my 1991 Si hatchie. Can i cut these connectors off and cap the wires? Or What should i do with them?
thanks for the help
Walter
Old May 20, 2005 | 10:26 AM
scul8r1990's Avatar
hmmmm the green plug was unplugged when i popped the hood? where does it go?
Old May 20, 2005 | 11:10 AM
scul8r1990's Avatar
no this is not that green plug, ill post a pic.....the radiator fan is plugged in..
the green plug i want to snip is wired into that little black box thingy bolted to the top of the radiator.
Old May 20, 2005 | 11:12 AM
CRX Toad's Avatar
Default Re: (scul8r1990)
My rule of thumb is to never cut anything off the harness it maybe needed later. Electrical tape and zip ties will keep it out of the way until you may need it.
Old May 20, 2005 | 11:15 AM
Tyson's Avatar
Default Re: (CRX Toad)
yeah, why cut anything anyway? its either the radiator fan or the ac compressor fan plug. just remove the AC harness completely. dont cut it.
Old May 20, 2005 | 11:18 AM
scul8r1990's Avatar
yea, i guess i shouldnt cut it. Where is the harness located?
thanks
Old May 20, 2005 | 11:19 AM
scul8r1990's Avatar
Old May 20, 2005 | 11:21 AM
91civicEX's Avatar
tie it up and bundle it near the airfilter. in case the new owner wants to reinstall the ac sometime
Old May 20, 2005 | 12:55 PM
Tyson's Avatar
Default Re: (91civicLX)
holy crap, im wrong!
green is NOT the radiator plug. the bigger, (female?) harness side of the radiator fan is green, but the electrical harness plug is not green.
BOTH plugs for the AC harness are green for each plug.
my apologies.
so yeah, thats an AC harness probably, but still dont cut anything. just remove it completely.
HellaStockEJ6
Oct 28, 2013 08:53 PM
661rex89si
Nov 30, 2006 07:08 PM
661rex89si
Nov 4, 2006 05:22 PM
Skunk.Werks
May 17, 2005 07:45 PM
