Code 43 - Changing O2 Sensor Questions
Alright I'm throwing a 43 randomly, and running shitty when car warms up so I'm changing the 02 Sensor.
My question is should I just buy an O2 Sensor from Autozone or whatever, or would I want to go somewhere else.
Are there bad vs. good 02 Sensors? Just never boughten a new one so making sure I get what I want. Any advice on what to buy or where to buy is appreciated.
Don't go aftermarket, stick to Denso units.
http://www.sparkplugs.com
$75 shipped for an OEM Denso unit. Direct plug and play.
I'd go with the direct replacement Denso unit. I, too, have used the Autozone universal replacement. Having to wire it up and only save around $25 over the OEM unit is not worth it. Buy a plug and play O2 sensor and be done with it. Is the code you're throwing for the primary or secondary O2 sensor?
Yes 43 is Fuel Supply System. Everyone else seems to solve with new O2 Sensor.
Plus I'm only running shitty when my car is warm, right at startup everything is good.
I've gotten a code 43 as well, but I got it after I wired in a new o2 sensor. Car still really really boggy. Anyone got a clue?
Just so I don't threadjack here, please check out my other post. I need some help here. https://honda-tech.com/zerothread?id=1253042
Autozone wanted $250 for OEM, and $79 for Universal. Looks like I'll be ordering I guess.
I remember people always talking about getting new ones for like $30. What ever happened to that?
check your intake air temp sensor.
mine had a break in the wiring harness, wasn't getting the 5 volts to one side of the plug, should be a red/yellow going to pin d15 in an eg. the other side is green, the same ground that goes to the map, tps, etc.
allisonmo2
21
Oct 25, 2008 12:52 PM
EK9_GRL
Oct 5, 2007 12:33 PM
amej8
Jul 11, 2006 06:25 PM
