JUN type 4 cam ?? is it real ?
Old May 20, 2005 | 08:55 AM
carboy_honda's Avatar
Default JUN type 4 cam ?? is it real ?
I read in this forum that JUN is making a JUN type 4 cam for road racing ? Is this true ? I am looking for a cam upgrade for my JDM ITR use for road racing ? Any reccomendation ,thanks guys
Old May 20, 2005 | 09:11 AM
97L-esVeeTeg's Avatar
Default Re: JUN type 4 cam ?? is it real ? (carboy_honda)
JUN 4's have been out here in the states for a while. IIRC Tbone (cam king ) ran these for like a day and half. I dont have specs but i believe they are crazy huge, v2v and p2v clearance may be an issue.
EDIT: Sorry for the repost
Old May 20, 2005 | 11:07 AM
iakona's Avatar
i thought those were the BC4s he had?
Old May 20, 2005 | 11:14 AM
Disco Monkey's Avatar
Default Re: (iakona)
titan motorsports used to sell the jun 4's i dunno if they can still get them or not.
Old Jun 5, 2005 | 04:21 PM
JUNEK9's Avatar
Default Re: (Disco Monkey)
I have a set...hopefully the motor will be done this week
Old Jun 5, 2005 | 06:17 PM
Tbone's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iakona &raquo;</TD></TR><TR><TD CLASS="quote">i thought those were the BC4s he had?</TD></TR></TABLE>
I had Jun 4's like a year and a half before the buddy4's..
I never got to run the jun 4's because they were too big. I couldnt even run them with the cam gears at 0 0 since clearance was only .025
Here were my clerance #'s with the 4's with .5mm oversized valves.
JUN 4 info: with the cam gears zeroed.
intake c/l 103° .502" net lift
exhaust c/l 101° .505" net lift
valve-valve cl = .025"
intake gear/exhaust gear - valve/valve cl.
0/2° retard .008"
0/2° advance .034"
2° advance/0 less than zero (stopped rotating crank, reached zero early)
2° retard/0 .030"
3° retard/0 .040"
other combinations for reference
2° advance/4° advance .033"
2° retard/2° retard .020"
3° retard/2° retard .025"
4° retard/2° retard .030"
4° retard/1° retard .038"
Steve Sakai tried to run them and he said with stock valves in his head that he couldnt even run them at 0 0 as the valve to valve was to close.
Old Jun 5, 2005 | 09:35 PM
eg6hatch3's Avatar
i heard about the same thing,,, i hope they are,,,, and if they are,, is going to be sick..
Old Jun 5, 2005 | 10:44 PM
DOHCtorTHRUST's Avatar
Default Re: (Tbone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tbone &raquo;</TD></TR><TR><TD CLASS="quote">
Steve Sakai tried to run them and he said with stock valves in his head that he couldnt even run them at 0 0 as the valve to valve was to close.</TD></TR></TABLE>
if he couldnt run the cams with stock valves, what were these cams made for? if i remember correctly, you have OS valves. so if both stock and OS valves wont work, how would anyone run them?
*scratching head*
Old Jun 6, 2005 | 05:41 AM
b19coupe's Avatar
Default Re: (DOHCtorTHRUST)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCtorTHRUST &raquo;</TD></TR><TR><TD CLASS="quote"> so if both stock and OS valves wont work, how would anyone run them?</TD></TR></TABLE>
There are tricks that machine shops can perform to the head to increase valve to valve clearance.
Old Jun 6, 2005 | 08:39 AM
pretty crazy cam spec , is it suitable for curcuit racing ?
Old Jun 6, 2005 | 05:57 PM
Tbone's Avatar
*scratching head*</TD></TR></TABLE>
I said he couldnt run them at 0 0 on the cam gears , I didnt say he couldnt run them at all..
Old Jun 7, 2005 | 08:50 AM
Ok guys, JUN3 or TODA B/C ?for high speed circuit usage ??
Old Jun 7, 2005 | 09:41 AM
juntuned's Avatar
Default Re: (carboy_honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUNEJ1 &raquo;</TD></TR><TR><TD CLASS="quote">I have a set...hopefully the motor will be done this week
I also have a set.......and we will soon see if I have any valve 2 valve issues. let me know what happens with your motor. have you done anything to compensate for valve clearance?
Old Jun 7, 2005 | 09:45 AM
juntuned's Avatar
Default Re: (Tbone)
0/2° retard .008"
0/2° advance .034"
2° retard/0 .030"
3° retard/0 .040"
so what are the tricks to increasing clearance and how far should clearance be in order to be considered practical/safe?..
can i use these cams in my b18c5 on stock valves.....what is your suggestions?
Old Jun 7, 2005 | 01:28 PM
mark_is_gay's Avatar
Default Re: (juntuned)
using any aftermarket cams on ur stock motor should have upgraded valves. just to be safe. and if ur running jun's 4 that deff get some aftermarket valves.
Old Jun 7, 2005 | 02:25 PM
johnzm's Avatar
Default Re: (b19coupe)
and how is this!?
i assumed that without a BUNCH of money, u cant change the
angle the valve opens to
the amount of space in between the valves
soo the only trick i can see is the machine shop reducing valve size even more than stock...
im confusssededd
Old Jun 7, 2005 | 03:19 PM
iakona's Avatar
they can raise the seat height, effectively reducing the amount the valve opens by having a shorter throw spring. i do believe you can also change the valve seat depth.
Old Jun 7, 2005 | 05:32 PM
VSBB6's Avatar
If they make stage 4 for H22 I'd jump on it.
Im currently running their only stage 3s for H22, loving it.
Old Jun 8, 2005 | 08:59 PM
juntuned's Avatar
Default Re: (VSBB6)
bump
Old Jun 11, 2005 | 04:58 PM
555R's Avatar
aftermarket valves are not necessary per se
it is the issue of oversize valves that jun does not recommend
that is the same for the Jun 3s also
which i have and run
you also cant run more than 1.5 degrees separation for the 3s so I imagine the J4s are probably even less in separation...
Old Jun 18, 2005 | 03:34 PM
no2psi's Avatar
Default Re: (555R)
what is the recommended minimum valve to valve clearance.? I have heard .030"
Also how do you conclude that you have enough or not enough clearance.?
Thanks,.
Old Jun 19, 2005 | 05:46 AM
555R's Avatar
Default Re: (no2psi)
clearnaces are found by claying the motor
a tedious process as you assemble and disassemble the motor
mine has just under 30 thou but it worked
Old Jun 19, 2005 | 09:17 PM
builthatch's Avatar
MiG-21 superfan
Default Re: JUN type 4 cam ?? is it real ? (eg6hatch3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6hatch3 &raquo;</TD></TR><TR><TD CLASS="quote">i heard about the same thing,,, i hope they are,,,, and if they are,, is going to be sick.. </TD></TR></TABLE>
what did you hear? what are you talking about!?
Old Aug 3, 2005 | 02:31 AM
got my Jun 4 now with Jun oversize valve and retainers but no specs ,need help
