Humming
Ok I noticed another problem in my car stereo after installing the amp and subs it hum very badly on am stations doesn't do it all the time but does some. It doesn't sound like the subs it is a high pitched squeal coming from the speakers it sounds like. It didn't do it before I installed the amp and subs but I don't see how they could have done anything. The HU is a JVC Aresonal anyone got any ideas on how to fix it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hometheaterman »</TD></TR><TR><TD CLASS="quote">Ok I noticed another problem in my car stereo after installing the amp and subs it hum very badly on am stations doesn't do it all the time but does some. It doesn't sound like the subs it is a high pitched squeal coming from the speakers it sounds like. It didn't do it before I installed the amp and subs but I don't see how they could have done anything. The HU is a JVC Aresonal anyone got any ideas on how to fix it?</TD></TR></TABLE>Is it happening with or without the motor running?
94
94
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hometheaterman »</TD></TR><TR><TD CLASS="quote">With the motor running I haven't tried to see if it does it with the motor turned off. </TD></TR></TABLE>Need to know........if its only there when motor is running, then it will be "engine noise" if its a whining kind of sound, [whistling] that gets louder as you draw more power , [turn lights on, rear window defog] and changes pitch when you rev the motor, [200-500 rpm] up and down, then its "alt. noise and its probably getting in through the RCA coard, [running too close to power wires, or if you are using cheap RCAs.
It can also be getting in through the power or ground wires to the amp, [ground loop] check the ground for the amp and the HU, also unplug the RCAs at the HU and the amp, [is the "squeal" still there?] BTW if it is more like a "squeal" and it's there with the motor not running, something that squeals, is hurting
94
94
i had that problem a while back i just replaced the head unit i got tired of ******* with it but good luck you may want to check to see if wires are connected tightly. My noise was coming from the head unit though
It's going to be hard to get rid of if it only does it on AM. It could be anything from your spark plugs, the wires, your ignition coil, to grounding issues, sheilding issues, etc.
If it's all the time, then use higher quality twisted RCA cables, and double check your grounding location is good.
My noise is coming through the speakers not from the actual HU if thats what you mean. I used the rca cables from the 4 guage Street Wires Kit are they any good? One thing I'm thinking about is that I grounded it to the bolt that goes through the metal in the trunk into the brake light thats in the window and I'm thinking maybe it is too close to the antenna in the window or something.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hometheaterman »</TD></TR><TR><TD CLASS="quote">My noise is coming through the speakers not from the actual HU if thats what you mean. I used the rca cables from the 4 guage Street Wires Kit are they any good? One thing I'm thinking about is that I grounded it to the bolt that goes through the metal in the trunk into the brake light thats in the window and I'm thinking maybe it is too close to the antenna in the window or something. </TD></TR></TABLE>That is a poor ground, find a bolt that gos into the floorpan of the car, seat and seat belt bolts are very good, even the studs on top of the shock towers are better, the reason the floorpan is so good is that in most cars it is one pc. of sheet metal all the way from the back of the car to the firewall up front.
If you pull your back seat out, you will find all sorts of bolts going into the floorpan of the car, 10mm and bigger. Don't forget to clean off all paint, so ground makes contact with the bare metal of the floorpan.
94
94
So basically do I need to pull the rear seat out? I have done it once when I replaced it and it was a lot of work wasn't hard but I don't really want to do it again if I can find a better spot. I was just in a hurry when I did it so I didn't take anything out to look for a grounding bolt.
No you don't need to pull the rear seat. Just use a ring termanal and run the bolt which holds the seat in, through the ring terminal. Make sure its contacting bare metal. Use a dremal with a sanding bit to get down to bare metal.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loccusst »</TD></TR><TR><TD CLASS="quote">Use a star washer too...they bite into the metal and give you a better ground. </TD></TR></TABLE>
Quick question about that. Do you put the star washer under the ring terminal or between the ring terminal and the bolt (on top of the ring terminal)?
it should go between the ground metal of the car, and the terminal on the end of your wire. I see so many people use those incorrectly by using it as a "locking washer". It's ment to dig into the ring terminal and also into the metal you're grounding to to help make a good connection
JohnnyEF
Audio / Security / Video
Nov 26, 2006 12:04 PM
IloveNewt
10
Mar 21, 2003 10:23 AM
