Engine Light, Please help!!
Old May 20, 2005 | 06:23 AM
Nay's Avatar
Nay
Default Engine Light, Please help!!
I just installed an MSD cap, rotor, wires and Zex plugs. My engine light keeps coming on. When I removed the old plugs 3 and 4 were severly damaged. Please Help. Engine is a 1st gen B16 minor bolt ons.
Old May 20, 2005 | 06:36 AM
SiR Inspired ED7's Avatar
Default Re: Engine Light, Please help!! (Nay)
what cel codes is it throwing out?
Old May 20, 2005 | 06:55 AM
highrevnef's Avatar
Default Re: Engine Light, Please help!! (88 Crx Si)
yea wut codes are they?
Old May 20, 2005 | 06:56 AM
Nay's Avatar
Nay
Default Re: Engine Light, Please help!! (highrevnef)
after market ecu no flashing lights, any other way to find out?
Old May 20, 2005 | 07:04 AM
EP3_05's Avatar
What aftermarket ecu? AEM, Motec, Autolink???
Old May 20, 2005 | 07:17 AM
Nay's Avatar
Nay
Default Re: Engine Light, Please help!! (91civic)
Wish I knew. Mechanic said put it in so I did. If it has the flashy lights where are they??
Old May 20, 2005 | 07:18 AM
highrevnef's Avatar
u might wanna try chaning the alternator. or if u got cash take it to the shop or somethin. sorry bro.
Old May 20, 2005 | 07:32 AM
EP3_05's Avatar
I am now beginning to doubt it is an aftermarket ecu but try this.
Pull back the carpet in the passenger footwell.
You should see a brass colored plate with a little window in it.
Turn the car to the on position so the dash lights come on.
Check to see if you see an LED flashing through the window.
Note: It should flash some while the CEL comes on at first. Then it should shutoff and begin to flash codes if there are any.
Codes are read as follows:
One long blink=10
One short blink=1
ie blink.......blink..blink..blink........pause...... .blink.......blink..blink..blink=code 13
The sequence will repeat itself over and over again. Good Luck
EDIT: Also how were the plugs damaged??? What do they look like?
Old May 20, 2005 | 07:47 AM
Nay's Avatar
Nay
4 had no electrode left and some of the ceramic was missing and the hook was gone, 3 was the same stuff just not as bad. I think the nitrous did it??
Old May 20, 2005 | 07:51 AM
Nay's Avatar
Nay
just checked there is no little window on the ecu?? It has a LH at the top and a big flat head screw in the center.
Old May 20, 2005 | 07:56 AM
EP3_05's Avatar
Can you take a picture and post it? What does it look like?
Old May 20, 2005 | 07:59 AM
Nay's Avatar
Nay
Ill try at lunch time thanks
syler
11
Apr 15, 2007 01:01 PM
nutcore
Sep 24, 2004 11:26 PM
DjFreeze
18
Apr 29, 2004 04:31 AM
nek0
Jul 9, 2003 04:49 PM
jjaeschke2
Apr 20, 2003 05:14 AM
