f22b into my 91 5spd coupe
Old May 20, 2005 | 05:58 AM
CB7DOHC's Avatar
Default f22b into my 91 5spd coupe
will a DOHC non-vtec f22b swap directly into my motor mounts and connect to all the hosing and piping???? i dont wanna hear if its worth it or not, please keep them comments to yourself. i just want to replace my stock f22a with 200k miles with something a lil different and definantly more power but cheaper than the h22 and thought the f22b would be a good swap. any input is appreciated thanks.
Old May 20, 2005 | 11:49 AM
TxTuner
Guest
Posts: n/a
Default Re: f22b into my 91 5spd coupe (91crxb16a)
Yes the f22b is a pretty straight forward swap but think of it this way.
You spin a rod bearing on the f22b.... good luck finding a replacement.
You spin a rod bearing on the h22.... they are a dime a dozen (just a figure of speech)
Old May 20, 2005 | 12:13 PM
CB7DOHC's Avatar
Default Re: f22b into my 91 5spd coupe (TxTuner)
i couldnt just pull a rod bearing out of an h23 or f22a?
Old May 20, 2005 | 12:18 PM
TxTuner
Guest
Posts: n/a
You're not getting the point. The f22b DOHC is strictly a JDM engine. Good luck trying to find parts if they break. But with the h22..........
See where I'm going with this
Old May 20, 2005 | 06:44 PM
CB7DOHC's Avatar
yah but with the $1500 saved i can build a nice turbo setup
Old May 20, 2005 | 06:45 PM
CB7DOHC's Avatar
another thing back to the swap, will the motor bolt up to my tranny? what ecu do i need? distributor? hoses? belts? all this is the info i need, thanks.
Old May 20, 2005 | 08:35 PM
D16Z6racing's Avatar
Default Re: (91crxb16a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91crxb16a &raquo;</TD></TR><TR><TD CLASS="quote">another thing back to the swap, will the motor bolt up to my tranny?</TD></TR></TABLE>
With 200k, you wanna swap just the longblock?...save yourself time and money. Do it all at once.
Do it right or don't do it at all.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91crxb16a &raquo;</TD></TR><TR><TD CLASS="quote">with the $1500 saved i can build a nice turbo setup</TD></TR></TABLE>
...well...you can start saving for a nice turbo build set up. Expect to pay $3k+, unless your a master mechanic doing it yourself.
My 90 has 260k all stock. I'm looking for a H23 full swap...cheaper, lower demand than H22, parts are available/easy to find, numerous upgrade possibilities, etc..
Think your options through 110% before deciding. Even a F22 SOHC VTEC is an upgrade.
93JDM_H22
Dec 4, 2007 04:30 AM
03K24A4EX
Aug 28, 2006 12:35 AM
humplick
Jun 22, 2004 11:52 AM
revlimitlude
Dec 17, 2002 11:57 PM
CHK4TIX
Nov 26, 2002 10:34 AM
