Overheating????
Old May 19, 2005 | 11:15 PM
drewcandraw's Avatar
Default Overheating????
well i just noticed that my car is getting hotter...i mean that heat i tihnk coming from the engine and is seeping into my car thru the dash vents and under the dash onto my feet....what does this mean...is my car in need of a coolant change or what???im not sure what to do can u guys help me out
Old May 19, 2005 | 11:20 PM
Redline130's Avatar
Default Re: Overheating???? (drewcandraw)
Where does the needle on the temp gauge go to?
Old May 22, 2005 | 10:10 PM
Default Re: Overheating???? (Redline130)
its like half way but sometimes a little more
Old May 22, 2005 | 11:45 PM
Redline130's Avatar
There are several possibilities that could be causing your car to run hotter. Things to check would be the radiator cap, thermostat, and water pump. Also, maybe your radiator is clogged.
Old May 23, 2005 | 12:35 AM
thumbtack's Avatar
turn the heater controls off... put it on internal air with the fan off and turn the temp to cold.
Old May 23, 2005 | 02:58 PM
Default Re: Overheating???? (thumbtack)
ok ima check water pump, thermostat, and try running on internals
Old Jun 4, 2005 | 04:03 PM
how do i know if my radiator needs to be replaced???i would appreciate the help thanks
Old Jun 7, 2005 | 04:09 PM
well i just found out that the cooling fan next to the radiator doesnt even turn on!!!so i think thats why i can feel my car get hotter inside...I was wondering how i can fix this problem without consulting a mechanic...Thanks...
Old Jun 7, 2005 | 10:37 PM
Redline130's Avatar
First thing would be to check the fuse for the fan. Next, check to see if the fan still works, just unplug the fan, and connect the blue wire to the positive terminal on the battery and the black to a ground. Last thing to check would be the thermal switch on the motor.
Old Jun 8, 2005 | 12:48 AM
StorminMatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drewcandraw &raquo;</TD></TR><TR><TD CLASS="quote">well i just found out that the cooling fan next to the radiator doesnt even turn on!!!so i think thats why i can feel my car get hotter inside...I was wondering how i can fix this problem without consulting a mechanic...Thanks... </TD></TR></TABLE>
Malfuntioning fans would not make your car feel hotter inside. On the contrary. When those fans switch on, they tend to blow hot air toward the air inlets at the base of the windshield. The only thing you would notice if the fans went dead is overheating when the car is idling, but not moving.
Old Jun 8, 2005 | 10:37 AM
ok ima try that out thanks fer the help
Ryebread1974
Sep 24, 2018 04:24 PM
MFButler
Mar 11, 2010 11:30 AM
freshgear
Jul 19, 2009 01:48 PM
bigslimdog
Aug 10, 2004 03:37 PM
Accord_Munch
Nov 13, 2002 06:12 AM
