How can I plug 2nd O2 hole under car?
Old May 19, 2005 | 09:23 PM
HYREV2NR's Avatar
Default How can I plug 2nd O2 hole under car?
I did a search but found nothing. I finally got my Hondata & I removed the second O2 sensor but don't no where to get a rubber plug for the hole in the floorpan. I tried using the one on the firewall & it doesn't fit quite right. It's a bit too small to stay there if I were to hit a bad bump in the road. Any ideas? Thanks.
Old May 19, 2005 | 09:44 PM
B2FiNiTY's Avatar
Default Re: How can I plug 2nd O2 hole under car? (HYREV2NR)
Duct tape it up
Old May 19, 2005 | 11:07 PM
HYREV2NR's Avatar
Default Re: How can I plug 2nd O2 hole under car? (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">Duct tape it up </TD></TR></TABLE>HHHMMMM...OK, I thought of that but didn't think it would hold. Maybe I should try some of that silver tape that has an aluminum foil look you can find in most hardware stores. I've heard it's real sticky & durable.
Old May 19, 2005 | 11:54 PM
Bbasso's Avatar
measure the size of the hole and go to a hardware store and see what gromets fit.
Old May 20, 2005 | 03:46 AM
Misfit's Avatar
Default Re: How can I plug 2nd O2 hole under car? (Bbasso)
I have some o2 sensor plugs that I found a year or so ago.. that is what I used..
Old May 20, 2005 | 08:26 AM
HYREV2NR's Avatar
Default Re: How can I plug 2nd O2 hole under car? (Misfit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Misfit &raquo;</TD></TR><TR><TD CLASS="quote">I have some o2 sensor plugs that I found a year or so ago.. that is what I used..</TD></TR></TABLE>U mean something to plug the hole on the floorpan right? Where did U find them?
Old May 20, 2005 | 09:24 AM
mstewar's Avatar
i used duct tape for a long time.. it actually will hold..
you can get a WIDE variety of grommet sizes at Advanced Auto..
Old May 20, 2005 | 11:57 AM
HYREV2NR's Avatar
OK speaking of plugging holes, Does the dealer have a block-off plug for the rear wiper hole in the hatch glass?
Old May 20, 2005 | 12:20 PM
DC231 Sean's Avatar
Default Re: (HYREV2NR)
Rubber Bushing (Acura Dealer) [76707ST7000] &lt;--- You only need this part if the current bushing on your rear wiper is damaged.
Bolt (Honda Dealer) [90156SH3000]
Plug (Honda Dealer) [90301SR3000]
Washer (Hardware Store) [5/16 Washer]
Old May 20, 2005 | 04:00 PM
HYREV2NR's Avatar
Default Re: (00PYDC2R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00PYDC2R &raquo;</TD></TR><TR><TD CLASS="quote">Rubber Bushing (Acura Dealer) [76707ST7000] &lt;--- You only need this part if the current bushing on your rear wiper is damaged.
Washer (Hardware Store) [5/16 Washer]</TD></TR></TABLE>Thank U & God bless U for a quick reply!!! U made my quest to find this part much quicker!
Old May 21, 2005 | 10:55 AM
HYREV2NR's Avatar
Found a way to rid the prob of the hole in floorpan. DYNAMAT!!! Works great. Now my R is 3 ounces heavier. Oh well.
Old May 21, 2005 | 12:26 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HYREV2NR &raquo;</TD></TR><TR><TD CLASS="quote">OK speaking of plugging holes, Does the dealer have a block-off plug for the rear wiper hole in the hatch glass?</TD></TR></TABLE>
Here's an article that describes the procedure with a Acura metal plug, I haven't used it.
http://www.team-integra.net/se...D=624
I believe this is how the 97 ITR came, without the rear wiper. OEM parts.
http://www.sandmracing.com/rearwiperremoval.html
The complete parts guides (the OEM way, and then a cheaper way.) for wiper removal and brake light removal. Pics too.
https://honda-tech.com/zerothread?id=1204610
I used:
Method 2 (cheap)
parts list
Grommet 91617-SB6-000 List 3.72
Sprockets
Dec 13, 2005 11:32 AM
T-RO
Jun 21, 2004 01:05 PM
2 point 0
10
Mar 17, 2004 05:00 AM
99ls
May 21, 2003 09:17 PM
ladysman
Apr 1, 2003 02:05 PM
